All I know is I've sold 112 in the last twelve months .. Zero fks given if ya'll poor folk can't afford em. Cos plenty people can and they ain't foreigners
What is happening in the west, or your locale, is a different situation to the east. Once the most expensive properties are bought up where do you think they will turn to for suburban living? It's a matter of time.
Yeah but how can you use a sample size from one suburb/west 'burbs to represent the buying population of Australia?
That doesn't fly with statistics yo'
Where my statistical brothers at?
Right here, let me crack open SPSS student edition (Alex kryptonite) and get a T value on his ass
  • Like 1
Nah man no need I get paid a truck load for doin it, a medal seems a bit over the top
& birds I talking about factors around buying not just the income to purchase price
Oh so you would like to add the increased cost of living in there to further assist birds' point?
There are no factors that can directly and heavily influence more than a Chinese buyer swooping in 70k above at auction. No population demographic shift dual income interest rate super owners grant will change that. There are REAs in areas who won't even answer customer emails if they don't have a Chinese sounding last name.
real question for Alex.
how long should I wait on a block that has been on the market b4 I low ball them?
think found the right 1 just think it priced a little high..
been sitting there for 3 months so far.
know dem feels
In any case no one in here is stating housing has at this point become unaffordable, simply that it is becoming less affordable as time goes on and will eventually become unaffordable to many. Just because this hasn't happened yet doesn't mean it never will, at the current rate it's inevitable unless things are changed.
  • Like 1
Timing isn't overly relevant to the transaction depends if vendor is motivated or not to meet the market.
Birds / ham - good luck is all I'll say for further reference review the bubble thread for reasons why your wrong
Huh?
Block of unused land has no benefit for the vendor. He/She cannot live on it or rent it out to pay the mortgage.
Any capital gain over the past 3-4 months would be hardly anything.
I reckon timing would play big for an unused lot, as long as it has some form of mortgage the vendor wants to flip.
my 2cents
exactly right.
a farmer is sub diving a Padock into 6 lots
5 - 6 acres each.
but that said he needs to run power/water to each (that part of the advertisement) plus fencing and such.
it's interesting there 6 blocks 5 currently at 350K 1 at 280
so they obviously trying to work out what price they should be at, from other blocks seen for sale I think 5 are 220ish and the one I want 250-260K
lol.
I'm happy renting for the time being. People getting bigger loans to pay for more expensive houses. I prefer money in my pocket even though it doesn't do any favours. Only benefit is I've got something to live off if work/pay slows down (which it has)
It's taking a holiday together for the last time before your life changes for ever. Not to mention the fact that you won't be able to have one for a long time afterwards
Not a difficult concept really
lol yeah, not a big fan of all the buzzwords and hashtag names for everything these days, but I don't see why you're getting so upset that a couple wants to go on a holiday together before they have a baby that can't travel for a while, not to mention less disposable income and complete lack of free time, what with having to feed/clothe/raise a child,
Nailed it
I understand pretty much none of what is being spoken about currently, I do however have a house which I can afford on a single income, because no women want me to be their life partner.
Lol you also don't earn average wage :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
