More credit to the ALP and shorten than the libs on this one. We all knew MT was going to get in eventually and they did NOTHING to prepare for this... they squarely deserve to lose
The fact they have no policies and a horrible track record that's still fresh in many memories would have been enough to get libs reflected.
Takes a long time to recover from such monumental failures.
it was weird as he wasn't "playing." He was seriously working hard all day.
haha little trooper!
Tell Mohsen's mates there's an adulterous gay Jewish rape victim living next door
They'll quickly displace it for you
lost it.
Not with Abbott at the helm... He was so toxic he was losing unrelated state elections. Every time the dude opened his mouth he made the situation worse, imagine what he could have done by the time the next election rolled around.
Apparently I'm established working class
Which is kind of odd when I selected the highest household income bracket and they go on to state
Members of the established working class have the lowest household incomes
Slightly retarded survey IMO...not much a fan of the original classifications that came from the UK either
I'd like to put it out there that Shorten is far more retarded than Abbott could ever be. He is still criticising Abbott's actions outside politics in the media...has someone told him he's no longer PM yet?
  • Like 1
Survey was retarded. Doesn't ask a lot of what would be required to be accurate
That's just desperation cause MT hasn't shown his Achilles heel yet. He will as all pollies do... but it won't help shorten, he missed the boat when it was right in front of him and will pay the price
Honestly they are equally retarded in very different ways.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
