Reference was to his Epping Plaza'esque full front and back print A$AP Rocky jacket.
Also his mate was in an orange and blue camo spray with Jordans and a flat cap
Really? Have you never seen how old Asians dress they have zero fashion sense pajamas are considered acceptable business meetings lol
so I'm in macau atm..
the very definition of what Hatish thinking off.
I could take a pic any direction and have his buyer photographed
so so no class.
that said went in for my 2nd fitting of my new suits today
anyone who can make me look that good deserves everything he charges.
Ahahahahahaha suck it Rossi you sooky f**king Italian. It's everybody's fault but yours isn't it ...
"Isa nota my faulta, ima the besta ana everybody acheated... itsa only afair when ima the cheata"
  • Like 2
lol he did well to come upto 4th at least
lorenzo too strong and well deserved, even if he came 2nd still would of won the championship anyways
Yes, he did well to come 4th. Very, very well infact. Still lulzy as f**k that he lost the crown due to cheating, then complained about others cheating though
Did any of the other riders breaks any race rules at Valencia? No? Then Rossi's logic is null and void. Same shit happens in motor racing.
If they were purposely lagging to give Lorenzo the win then overtake them with your skillz Rossi, and then overtake the person you don't believe deserves to be champion lol
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
