I thought all insurance claims where they pay out rather than fix the car were automatically a stat write off?
it would then be sent to Auction. Some one bought and trying to flip to make some profit.
either that or the VIN plate been FKed with?
Makes sense.
Possibly stolen straight from dealership then later recovered. Have heard a few stories of those with the VF GTS
" SCHEDULE 6
Section 16BA
CRITERIA FOR CLASSIFICATION OF STATUTORY WRITE-OFF—LIGHT MOTOR VEHICLES
1 Definitions
In this Schedule—
excessive fire damage has the meaning given in clause 14;
excessive stripping damage has the meaning given in clause 16;
excessive structural damage has the meaning given in clause 5;
excessive water damage has the meaning given in clause 15;
"statutory write-off" means a vehicle that is a statutory write-off within the meaning of clause 4.
2 Application of Technical Guide
(1) A person who, in accordance with this Schedule, is assessing whether an area of a vehicle has been fractured, cut, cracked or buckled or is folded over onto itself must make that assessment based on the relevant diagrams contained in the Technical Guide.
(2) In this clause, "Technical Guide" means the "Damage Assessment Criteria for the Classification of Statutory Write-Offs" approved by Austroads Ltd ABN 16 245 787 323 from time to time.
3 Prescribed structural areas
s. 28
For the purposes of this Schedule, the structural areas of a vehicle are—
(a) the roof;
(b) each of the pillars;
© the floor pan;
(d) the firewall;
(e) as applicable—
(i) each of the the longitudinal structural rails; or
(ii) the chassis;
(f) the vehicle suspension;
(g) mechanical components;
(h) the supplementary restraint systems.
4 Statutory write-off
A light motor vehicle is a statutory write-off if it is written off and has been assessed, in accordance with this Schedule, as having—
(a) excessive structural damage; or
(b) excessive fire damage; or
© excessive water damage; or
(d) excessive stripping damage.
5 Excessive structural damage
(1) A vehicle has excessive structural damage if three indicators are found in the vehicle.
(2) In this Schedule, "indicator "means—
(a) excessive damage in a structural area, determined in accordance with this Schedule;
(b) deployment or activation of a supplementary restraint, determined in accordance with clause 13.
(3) For the purpose of calculating the number of structural areas which have been damaged—
(a) excessive damage to separate pillars or to separate longitudinal structural rail or chassis is to be counted as a separate indicator;
(b) each different and separate area of excessive damage to the floor pan or firewall is to be counted as a separate indicator;
© each incidence of excessive damage to a suspension station is to be counted as a separate indicator if clause 11(2)(a) applies;
(d) excessive damage to any part of the roof is to be counted as a single indicator;
(e) excessive damage to any or all of the mechanical components specified in clause 12 is to be counted as a single indicator;
(f) deployment or activation of any or all of the supplementary restraints specified in clause 13 is to be counted as a single indicator.
Examples
A vehicle has excessive damage in two pillars and in the roof. The vehicle is a statutory write-off.
A vehicle has excessive damage in two longitudinal structural rails and the front right suspension mount is damaged. The vehicle is a statutory write-off.
6 Damage to the roof
s. 28
The roof of a vehicle has excessive damage if it has been loaded so that an individual structural element or member—
(a) has been structurally—
(i) fractured; or
(ii) cut; or
(iii) cracked; or
(iv) buckled; or
(b) is folded over onto itself.
Note
A cut includes the situation where the roof has been cut by emergency services to permit occupant extraction.
7 Damage to the pillars
A pillar of a vehicle has excessive damage if it has been loaded so that an individual structural element or member—
(i) fractured; or
(ii) cut; or
(iii) cracked; or
(iv) buckled; or
8 Damage to the floor pan
(1) For the purposes of this Schedule, the floor pan of a vehicle
(a) includes the inner sill panel where the panel attaches to the floor pan;
(b) does not include—
(i) the outer sill rocker (rocker panel); or
(ii) the internal stiffener; or
(iii) the braces between the inner and outer panels.
s. 28
(2) The floor pan of a vehicle has excessive damage if it has been loaded so that an individual structural element or member—
(i) fractured; or
(ii) cut; or
(iii) cracked; or
(iv) buckled; or
9 Damage to the firewall
(1) A vehicle has excessive damage to its firewall if the firewall has been loaded so that an individual structural or member element—
(i) fractured; or
(ii) cut; or
(iii) cracked; or
(iv) buckled; or
10 Damage to the longitudinal structural rails or chassis
(1) For the purposes of this Schedule, the longitudinal structural rails or chassis do not include a deformable end plate that has been designed to be removed and replaced.
(2) A longitudinal structural rail or chassis of a vehicle has excessive damage if it has been loaded so that an individual structural or member element—
(i) fractured; or
(ii) cut; or
(iii) cracked; or
(iv) buckled; or
(3) If both longitudinal rails of a vehicle are damaged to the extent that they both require Original Equipment Manufacture replacement, that damage must be counted as excessive damage to three areas.
11 Damage to the suspension
(1) The suspension of a vehicle has excessive damage if there is collision-induced damage to a suspension mount to the chassis or body.
(2) In assessing damage to the suspension—
(a) if an independent suspension unit is damaged, so that its mount to the chassis or body is damaged, each station is one area of excessive damage;
(b) if a live axle is damaged, so that a mount to the chassis or body is damaged, the suspension of the vehicle must be counted as one area of excessive damage for each axle.
12 Damage to mechanical components
The mechanical components of a vehicle have excessive damage if collision-induced damage has caused one or more of the following to be cracked, deformed or broken—
(a) the engine block;
(b) the transmission case;
© the differential case;
(d) the axle housing.
13 Deployment or activation of supplementary restraints
s. 28
For the purpose of this Schedule, there has been deployment or activation of a supplementary restraint if—
(a) there has been deployment of an airbag (whether frontal, side or curtain) within the vehicle occupant cabin; or
(b) there has been activation of a seatbelt pre-tensioner.
14 Excessive fire damage
A vehicle has excessive fire damage if—
(a) as a result of fire, paint on the vehicle (whether internal or external) has blistered on any three of—
(i) the roof;
(ii) a pillar;
(iii) the floor pan;
(iv) the firewall;
(v) longitudinal structural rails or chassis; or
(b) as a result of fire—
(i) the vehicle has sustained a combination of exterior and interior fire damage; and
(ii) the vehicle has suffered damage to the extent that it is written off.
15 Excessive water damage
s. 28
A vehicle has excessive water damage if the internal cabin of the vehicle has been inundated with water (irrespective of whether the water is fresh, brackish or salt water) to a level above the level of the inner door sill.
16 Excessive vehicle stripping damage
A vehicle has excessive stripping damage if—
(a) it has been stripped of interior or exterior parts, panels and components such as wheels, bonnet, guards, doors, boot lid or interior parts; or
(b) by reason of that stripping it is written off.
Austlii isn't always up to date
Like 0.1% of the time
Best to use the government websites
Nah, if i am ever doing something THAT important I have a team of lawyers acting for me anyway :P
love it when my gtr misfires badly at low rpm's then stalls in the middle of the road. luckily after 5 mins i could get it started and limp it home. the spark plugs are so black that they are black (can't think of anything funny) time to see what caused them to foul so quickly.
love it when my gtr misfires badly at low rpm's then stalls in the middle of the road. luckily after 5 mins i could get it started and limp it home. the spark plugs are so black that they are aaron (can't think of anything funny) time to see what caused them to foul so quickly.
Spark plugs so black you thought your engine was a Kardashian?
That's just racist mate pull your head in or get out of my country.
I do like that one, it certainly acts like a kardashian, it's an attention seeking whore!
f**k off lol
when are you converting?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
