Ditch racv. Problem solved. Saves you headaches if you end up making a claim.... Oh wait that's every insurance company
What headaches?
Going through a claim with RACV with the Evo X at the moment
Herald Sun tells me i need to subscribe it to read
But will make note of Hoverboard Vic laws
Speaking of accidents saw this thought it was funny, some people shouldn't have a licence
What headaches?
My headaches with were organising repairs through their people. Repairs had to be done soon or it had to be requoted or some Shit. I was working all over the place at the time so it was super inconvenient (especially considering how much they charge for business insurance) and then I got screwed over with the hire vehicle. And then was $150 out of pocket from additional charges from the hire vehicle (which isn't RACVs fault, but pretty poor form I thought)
Fair enough
I thought having the most unreliable engine ever put into a Skyline would be enough of a drawcard for him
No that would be greg's
But i see what you are getting at
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
