look at moi, im a journalist huehuehuehue
http://zeitakuvip.com/home/2016/01/21/zeitakuvip-first-night-cruise/
(yes there are grammatical errors. i cant edit it)
They really need to rename that car club, it's a terrible name that is hard to remember :P
My mate on fb today
CENTRELINE SUSPENSION: MY STORY
Just a heads up for anyone here with their pride and joy wanting to go Centreline Suspension, im not the first to be lied to or overcharged by this "premium" suspension company.
I ordered Hard Race camber arms (front and rear) and a wheel alignment.
i got quoted by Typre power North Melbourne at parts + $260 labour
I called Centreline and they explained the difference in their service compared to Tyre Power and always use the excuse "we cant give you a price it depends on whats involved but we are premium and can trust us with your car" ... so i got slugged $520 labour
When i went to pick up the car they said "the front is hardrace, rear is ZZS, same factory" i was a little annoyed at this as a courtesy call would have been nice. I like to keep things uniform and would of been nice to see same brand front and rear.
When i jacked the car up at home i find that the front is SRI and the rear is ZZS, nothing what he mentioned, and charged me prices more than what SRI is, thinking i wasnt going to notice.
I went back to him and explained how you cant just choose what you want for my car if i asked for Hardrace and you havent even called me to ask me if i wanted these brands. More the fact he lied about what he installed and overcharged me.
After arguing, his best resolution was to reinstall my stock arms and not reinburse my $520 on labour. How the f*ck is that any good to me?
Not impressed with the "premium" service they claim themselves to be, ive been overcharged on labour, lied to on parts, and overcharged on parts thinking i wasnt going to check.
Theyve made a name for themselves, and now think they can do what they please.
Just a heads up for anyone needing to get work done to there car
It is becoming more apparent by the day that Labor are simply choosing not to contest this election... will be interesting to see their financials post election and see if they even made it to $100 in campaigning expenses
http://m.theage.com.au/federal-politics/political-news/malcolm-turnbull-extends-huge-lead-over-bill-shorten-in-first-poll-for-2016-20160122-gmc9w7.html?utm_campaign=echobox&utm_medium=Social&utm_source=Facebook
They are probably keeping him there to ditch after the election rather than burn whoever they have in mind in an election they are likely to lose anyway.
They probably also don't want to inherit the budget in it's present state and further propagate the myth that Labor can't manage a budget.
It's actually probably a better long term strategy to lose thus one
you don't actually think its a myth do you? like seriously its documented concrete evidence factual information that labor are hopeless with the budget.
given the resounding failure of the PUP party i think people may be more likely to shy away from independents..
greens will always be there cos ya know people like ham are allowed to vote..
You know there are political positions other than extremes right?
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
