I had the R34 when I bought this, so when Patrick suggested I buy it, I actually did.
Fuck me, was the editor on leave or did he just want everyone to see the real Mohsen?
The only thing more annoying than an iPhone fanboi... is an android fanboi...
If you genuinely think you NEED all the features and modifications available on an android and an iPhone won't cut it... You probably need to step back and have a good look at your life
  • Like 2
So true
lol like to see you use an iPhone to remotely ping your company server via vpn so you can find out how long it'll take them to receive your data packet containing encrypted binary for "iPhones are shit"
/averageandroiduser
something simple like making your own ringtones or message/alert tones and getting them to work properly on an iphone, its unnecessarily complex.
Want to grab photos/files/manage downloaded files/run a gameboy emulator and seamlessly play games with gameshark codes? so much more effort and essentially forced to have iTunes installed on every computer you plug it into.
Even bluetooth is just a PITA on iphone.
But what tipped me over the edge was requiring updates on the phone in order to sync/use iTunes. If you're phone is 1-2 models old and there is a new iOS version, the phone is basically f**ked. its running an OS that the phone can barely process on its own, let alone with 12GB of pics, videos, music, apps.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
