something simple like making your own ringtones or message/alert tones and getting them to work properly on an iphone, its unnecessarily complex.
Want to grab photos/files/manage downloaded files/run a gameboy emulator and seamlessly play games with gameshark codes? so much more effort and essentially forced to have iTunes installed on every computer you plug it into.
I thought you were supposed to be arguing AGAINST my point
I can run Torrent on my Android tablet...that make sit far superior to an Ipad..
I can get work email on my iphone..that make it far superior to an Android.
right tool for right job...motto for my life.
and yes I am expecting many comments about what sort of a tool I am..
6 boost makes awesome manifolds huh?
i saw something with a bunch of people complaining about external gate locations and welds, nek minnit they get thrown around in every other thread about being the go-to people for manifolds. i dunno anymore.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
