Getting another dog Leigh?
I think having another dog helped the process for us
Nah, my parents have just hit 60 and retired they want to travel a bit I think and at the moment don't really want another dog. I live in a 2 bedroom unit with a courtyard type setup (no grass or anything) so cant really have a dog.. plus sometimes I work long hours / travel etc.
Any other wastelanders also motorcycle riders?
yes I've got 2
New whip for a few days.
Quite nice actually. But bluemotion fuel saving measures are shitting me up the wall.
Otherwise not bad for a hire car (extra <$10 a day over Hyundai i20)
the Brutales look SO f**king good. Always wanted to ride one.
Got a Suzuki B-King 1340. Fairly ridiculous.
Very light and nimble they are, I think a good 50kg lighter than the bking! lol
Im thinking about selling it actually due to lack of use lately and just keeping my motard/dirtbike
Hahaha yeah most bikes are a good 50kg or more lighter than the BK. It feels nimble when it's on the move but can be a REAL bitch to push around.
dudes offered me a 2010 CBR1000R For the beamer...
I had a bloke email me yesterday asking if I wanted to swap the 2014 Kawasaki Z1000 I'm selling for a 2014 Kawasaki jetski. Why would I want to swap for essentially a sea-faring version of what I'm selling?
you'd take a hard dick and some bubblegum, lets be honest
LOL
http://www.9news.com.au/national/2016/02/05/05/25/man-charged-over-alleged-street-race-that-claimed-the-lives-of-two-melbourne-teens
what a crock of shit... they are actually charging him with culpable driving and dangerous driving causing death.
They even tried to oppose bail ffs
Justice system is a joke. Seems to come down hardest on those who deserve it the least and go easiest on those who deserve it the most. Like that guy who raped and killed that girl in the northern suburbs a few years back... had 14 previous rape charges or something similar. Only served a few months or so for each charge.
I feel like it's just because 'hoons' are the media boogeyman lately. The justice system has always seemed to pander to whoever the media is targeting at the time.
Edited by Jake_R34
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
