We just work flexible hours at work. Come in whenever and leave whenever. As long as the job is done NAB are happy for us to do whatever we want. Funny thing is most of us end up working longer hours because of this.... Sneaky NAB lol.
When OT is on offer we just come in/work from home/go to a business banking centre and do what we want then tell them. Some people literally do 40+ hours of OT when it's on offer
That's the way a company should be; it's the single most efficient organisation plan and hardly any embrace it. Puts responsibility for productivity and output right into the hands of the employee.
other than our call center that how we work.
Surge tank if your worried about fuel starvation... Not needed unless running semi's on track I reckon (depending on tank design)
But knowing SAU, Mohsens car will catch fire at the fuel pump and Greg's will still starve from fuel when exiting his driveway
I went through 2 x 040's and a walbo 255 when I had a bad batch of fuel and didn't realise that was the cause of the deaths... grit in the tank for like 9 months....
Cleaned it, then went to a Walbro 460.... E85 compatible and it's been lovely ever since.
Walbro's are quieter and smaller in size than the Bosch's... go the Bosch and hard mount it poorly in the tank if you want the whine. because racecar.
Walbro 460.
wire it properly
overkill the shit out of the wiring
Good for the amount of KW on E85 you'd want before it becomes a laggy piece of shit
I think you should listen to Greg's suggestion, he sounds like he's on the right track
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
