Myself included...as I've joined the ranks of people getting screwed at house auctions
540-590 range
Opening bid 620
Sells for 761
Sold for 600 4 years ago, area has had 27% capital growth, median house price 650 lol
  • Like 1
540-590 range
Opening bid 620
Sells for 761
Why would the range be less than the previous sale price? Sounds a bit off from the beginning...
Yeah, real estate agent got a scare when he called us asking if we had any offers and we said we knew it had sold for 600 previously...he spouted some shit about them being desperate to get rid of it, prolly to cover his ass.
Oil return line to Turbo? I have swapped that already sadly.
I should probably also say that it looks like it's dropping on the front sway/running down the sump.
Can it be anything other than the front main and/or oil pump gasket?
Don't see why they would be load-based however.
What do you mean A4 sized oil leak? Bruh cars oil pressure usually rises with revs, you should know this. More pressure = More likely to leak
If it's coming from the front then it's likely to be Cam seals or Crank seal.
Yeah I figured it was pressure related, but wasn't really sure how more pressure wouldn't just cause something to fail fully.
What I meant by a4 sized, is that the patch on the plastic cover under the engine (under the sump etc) is about the size of an A4 sheet of paper.
Don't know much about oil (of all the problems Ive had this one is new)
Cams all look dry, well rocker covers at least. Nothing is oily above where the Harmonic balancer is, so I figure it has to be the crank seal, but again, don't really know shit and could very easily be something else I never knew about
so ive been thinking of what JayZ passed on to us, and im not sure of his situation.
Did he have bitches, and that theyre not a problem or that he didnt have bitches therefore they werent a problem?
Sometimes it's hard to see a cam seal leaking, usually you'll see it down the side of the lower cover and pooled around the crank. It's all about finding the highest point that the oil is leaking from, oil can't drip upwards after all.
Both
He was saying that bitches present no problem for him, when he has them and when he doesn't.
Are you sure it's oil and not ps fluid?
It was originally gold, and I thought it was trans fluid (Transmax Z is gold) but it was just new oil as it gradually got darker, and the fact all the PS stuff was completely spared. It also gets all over the hard trans lines and where they connect to rubber joiners so I've had many "Ah I bet its just XYZ!" to be found no, sorry, it is not XYZ.
This is what I thought too, the highest oil was on the merge point of the top and lower cover, I can't think of anything else it really could be, hence the post because I r n00b
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
