Haha I remember someone talking about it, but it was good cause I got items I needed but didn't have yet like some wireless bluetooth/USB headphones, computer speakers and UHF radios.
Yeah we definitely need UHF radios, haven't been able to live without them too well for this long!
I'm not building a cubby house without walkie talkies; what planet are you from woman
Had a ride along with some cops from Knox and Nunawading, was quizzing them on the way. The one from Knox said Pettett is still on the books there and would fine his own mother :rofl:
Hey Greg, just spotted you on the Natsoft Results for Tampered Winton yesterday.
Why you only do 2 laps?
http://racing.natsoft.com.au/results/
-> Circuit
-> Tampered
-> P1 results...
A few reasons. Profit takers; all it takes is one institutional investor to cash out their winnings and that can be enough shares to bring it down a bit. Then if people have stop losses set, the lower price can trigger these to sell off and share price will go down further. Anticipation that an announcement will come / be made and it doesn't happen can hinder buyers or make people sell out.
The share was getting good news over Christmas and I watched it fall from 1 cent to 0.6 cents...was asking wtf but sometimes the market just does its own thing, another reason shares are risky.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
