Just curious if an auction is for a foreclosed property does the Realtor have to state this? Or you're meant to gather this from the contracts?
Mates place is going up in a couple of weeks.
no, quite often agent is forbidding from disclosing this.
quite laughable as we stand next to the notice at the front door stating property has been repossessed... whoever comes up with these rules is a joker.
nice
at least he will finally be out of debt.
nice
provided it sells for enough to clear whats owed..otherwise they'll likely chase him for the balance depending how big the debt is.
banks give no fkz about you being broke.
it a very nice apartment in prahran that he had for nearly 10 years, guessing it gone up by more than he owes, might even get some cash back
true but the legal fee's will get added on too and they are hugeeeee
True didn't think of that
That said would have been easier if he just got a job and paid the bills rather than going out clubbing every night cos his wife left him
Most of the laws around this are with regards to the serving of notices on unwilling parties.
Dezz you should of invested in one of these mate:
Half price and only 10k now
https://www.ozbargain.com.au/node/239653
I don;t get it..
the 2 decanters and the 4 glasses are worth 1400$
so there some coasters, tray and the back light fridge, how does that get to 20K let alone 10K on sale
free refills for life?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
