green wedge zone.
means i cant subdivide into blocks?
05/09/2013 VC103
35.04-3 Subdivision
A permit is required to subdivide land.
Each lot must be at least the area specified for the land in a schedule to this zone. If no area is specified, each lot must be at least 40 hectares.
A permit may be granted to create smaller lots if any of the following apply:
§ The subdivision is the re-subdivision of existing lots, the number of lots is not increased, and the number of dwellings that the land could be used for does not increase.
§ The subdivision is by a public authority or utility service provider to create a lot for a utility installation.
http://www.dtpli.vic.gov.au/planning/about-planning/improving-the-system/reformed-zones-for-victoria/reformed-rural-zones/green-wedge-zone
05/09/2013 VC103
35.04-3 Subdivision
hmmmmmm so from what i can gather, i CANNOT subdivide 8ha into smaller blocks and never work a day in my life once i sell them.
but there is the possibility of the zoning changing due to its close proximity to high st and donny brook road....
So apparently you dont get paid out super when cashing out your annual leave after leaving a job? hrmm I thought you did
"Hi Leigh,
No super is payable on lump sun termination on the leave entitlements."
http://calculators.ato.gov.au/scripts/net/SGCalculatorWeb/help/Amount.aspx?ms=Businesses
"Accrued annual leave, long service leave and sick leave paid as a lump sum on termination" is in the not-included list... So is overtime it seems...
Hamish or anyone else for that matter, have you had Kobe beef? If so, how was it?
technically no, effectively yes.
I have had beef from Kobe descendants with a pure bloodline.
Shit is flat out amazing. you can taste it the next day
by FAR the best steak I have had.
KOBE BEEF.
i start salivating whenever i describe what it tastes like.
if you want something similar, visit wagyu ya in south yarra.
also, so many people asking me why im deleting them from Facebook.
well stop posting and commenting racist anti muslim/ arab stuff you dickheads.
KOBE BEEF.
Cool going to Tokyo tomorrow night
Lots of people saying to eat Kobe beef so will have to try
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
