green wedge zone.
means i cant subdivide into blocks?
05/09/2013 VC103
35.04-3 Subdivision
A permit is required to subdivide land.
Each lot must be at least the area specified for the land in a schedule to this zone. If no area is specified, each lot must be at least 40 hectares.
A permit may be granted to create smaller lots if any of the following apply:
§ The subdivision is the re-subdivision of existing lots, the number of lots is not increased, and the number of dwellings that the land could be used for does not increase.
§ The subdivision is by a public authority or utility service provider to create a lot for a utility installation.
http://www.dtpli.vic.gov.au/planning/about-planning/improving-the-system/reformed-zones-for-victoria/reformed-rural-zones/green-wedge-zone
05/09/2013 VC103
35.04-3 Subdivision
hmmmmmm so from what i can gather, i CANNOT subdivide 8ha into smaller blocks and never work a day in my life once i sell them.
but there is the possibility of the zoning changing due to its close proximity to high st and donny brook road....
So apparently you dont get paid out super when cashing out your annual leave after leaving a job? hrmm I thought you did
"Hi Leigh,
No super is payable on lump sun termination on the leave entitlements."
http://calculators.ato.gov.au/scripts/net/SGCalculatorWeb/help/Amount.aspx?ms=Businesses
"Accrued annual leave, long service leave and sick leave paid as a lump sum on termination" is in the not-included list... So is overtime it seems...
Hamish or anyone else for that matter, have you had Kobe beef? If so, how was it?
technically no, effectively yes.
I have had beef from Kobe descendants with a pure bloodline.
Shit is flat out amazing. you can taste it the next day
by FAR the best steak I have had.
KOBE BEEF.
i start salivating whenever i describe what it tastes like.
if you want something similar, visit wagyu ya in south yarra.
also, so many people asking me why im deleting them from Facebook.
well stop posting and commenting racist anti muslim/ arab stuff you dickheads.
KOBE BEEF.
Cool going to Tokyo tomorrow night
Lots of people saying to eat Kobe beef so will have to try
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
