Basing .035 on the recent new share release. That's what they offered the big boys so this what I base my roving off
Seems I was correct...now to see what it does..
Considering they sold more for .031 I think will bottom out around .033 and then I might think about some
You don't get to call two different floors...pick one that it will stabilise at.
I can't see much support in the buy side, only 12 million shares between current price and 2 cents...and there is heavy manipulation going on with 15 million share orders being traded back and forth. In auction it is being dragged down one pip at a time each day. I cashed out and will be back in when it starts climbing again. Got sick of watching profits piss away again. Still confident it's a great long term prospect but missing out on acquiring more shares for the same money if I don't try to buy in lower as it sinks.
I'm gonna say 2.8
I hope it doesn't, but our last capital raise to private investors pulled the share price down just below the share issue price. Wouldn't surprise me if it happens again.
On the plus side can pick up cheap shares.
I'm gonna say 2.8
Think you called 5.0 (may have been 4.0) as the floor....
Yep I was wrong...but how long should it stay there before you can call it a floor, cause it hung around that for weeks.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
