Any of you IT kunce know what this is? It's come up the last two times I've rebooted my laptop.. Just sits there at that screen and I have to turn the power off to reboot it again, then it reboots as normal...
here:
http://bfy.tw/6KZ3
pfft noob
just mute volume. go do something else, come back. repeat. if its a well-designed test you can flick back through previous slides.
lol yer basically did that but couldn't walk off as every minute needed to 'next' the slide..
Speaking of IT kunce, are any of you/them normal?
Been working at a large data centre since Jan and the amount of f**kin weird f**ks that come in there is astounding. It'd be easier to count the normal-ish ones.
RE: capital gains and losses, clearly I've experienced plenty of the latter...Can you actually claim that as a loss at tax time? Was under the impression you had to pay on gains but just bend over and cop the loss, in typical government rape fashion.
Yeah a lot of the 'specialized' IT guys that purely work in datacenters, massively in depth into networking or a particular technology are weird, you know those star wars or world of warcraft neck beard types.
The small-medium business IT guys ain't so bad in my experience because they don't have to be 'THAT' technical to run a small - medium sized business network.. tl;dr data centers full of weirdos yes.
Any of you IT kunce know what this is? It's come up the last two times I've rebooted my laptop.. Just sits there at that screen and I have to turn the power off to reboot it again, then it reboots as normal... 7f1c535ea099bb6269fbe5dfa8fe7fb7.jpg
quick google suggests something to do with your windows 10 install or upgrade..
http://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/starting-watchdog-initiation-on-black-screen/945df18d-3fb7-466b-90de-150bd0abfcd1
as suggested download the windows 10 ISO, create bootable USB (needs to be 8gb or bigger i think) start up to USB and then run a windows repair.. should fix
or do nothing if you cbf doing that
Why thanks
Blazer and untucked shirt, do not want
He's at the start of his journey... No doubt it'll be tucked in by the time he arrives at his destination to pound some gash by flashing around his parents money.
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
