i just realised that my sig is gone ;(
got gloria stereo running last night. not tuned yet, but already sounds good. keen to hear how much effect the deadening has. its a shame a good stereo doesnt stand out like a bad stereo does, teach the falcon owner across the road that bass should not be heard only in rattles when outside the car.
i lol @ the outrage at Pauline getting in.. or actually whoever its like nobody even likes them.. well newsflash they didnt get there by accident clearly somebody voted. so many sore losers - looking @ you hamburger
As of now One Nation have received 353,781 Senate votes nationally, 4.1%. That's a +3.5% swing her way. But in her home state of Queensland its 9.1%, a +8.5% swing which is just scary for anyone living there who is not of pure blood.
I think the problem for her will be that she's got backing from these grubs, but now she's going to need to take her message into the Senate, and she'll need to deal with adults.
I just can't wait for the media coverage.
The other statistic that is shocking me (I did a FB post about it the other day) was regarding the level of Informal Votes. Some states (Vic and NSW) have over 6% informal votes. This could be enough votes to completely switch the balance of power, but of course their vote doesn't make a difference. lol
Your sig is still sitting there within your profile, i'm pretty sure that sigs have been disabled in the new site (possibly temporarily to reduce load on the new server)
You think that because she has a bunch of uneducated redneck morons believing the hatred and lies she peddles that no one should be upset? she is now a part of the decision making process in our country. She is dangerous, delusional and either uneducated or highly immoral (likely both)
also... Alex pls. You'd cry yourself to sleep for a month if the ALP got in
Agree or disagree, love/hate her...she did kind of warn Australia in the 90s about some sort of Asian takeover...
Not that we've seen any of that come to fruition :whistling:
Should we heed warning on Islam?
  • Like 1
Well you are referring to property obviously, so there are 2 scenario's here:
1) Liberal - It's not an issue and housing can rise for ever with no ill effects
2) Labor - It's a huge issue however a minor change to negative gearing will magically fix everything
Therefore... under either government we are 100% secure and don't need to worry
yes and your jacquie lambie, ricky muirs etc are outstanding candidates.. among others.
to be quite honest its largely irrelevant to me who is in power as when you get to a certain level you get zero benefits and are a target for both parties - slightly less when libs are in i will concede. I vote liberal because my personal opinion is they do a better job of the economy and growth than labor - whether thats right or wrong its my opinion.
Soooo...you're saying...we should vote for Hanson?
you didnt - its merely an example that being outraged at her being elected is ridiculous when the reality is the state of politics in this country is woeful.
heck labor celebrating closing the gap / winning the election is just a reflection of no other options as im sure many would argue they are equally hopeless.
48 minutes ago, dezz said:
On 7/5/2016 at 9:14 AM, dezz said:
Alex, you know a Paul Boicos / Nick Meddis / Brendan Loc Tang or Brenda Ngan?
sorry man i dont come in here often - not personally but if you want pm me i will know people who do or can probably help if its real estate related
  • Like 1
1 hour ago, joeyjoejoejuniorshabadoo said:
Pauline Hanson being voted in is concerning on a number of fronts, not just political.
clearly most people agree there are no real options at present
while some (most) things pauline comes up with are ridiculous i cant say i find everything she says or believes in is unreasonable - i suppose them same goes for pretty much any candidate - apart from those anti vaxxers
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
