11 hours ago, Borci88 said:
cbf taking my tool box home to do it l0l.
All good brah, was worth a try hehe
I'm at that awkward moment undecided to throw the brakes on and then throw a few k into the engine for some fun times.. or just not waste my money, keep saving and sell it in 1-2 years for something different.. too bad at this stage there's nothing better I'd want instead of it :\ new performance cars suck!(<45k) I wouldn't go a new ford, nothing has changed since I got mine, evo meh old now, sti engine is old AF waiting for an update, mustang would feel like a downgrade, BRZ slow, commodore would feel like the same thing I already got with slightly better interior..
Maybe I should just #yolo and buy another bike
Edited by UNR33L
apparently nsw people give some good head.
come here jason.
bmw sold.
thank you god, most merciful father., or should i say, loaded viet farmer whos only gonna use it to drive to the fields in mildura. #toomuchmoney
2 hours ago, Leroy Peterson said:
88e is long term m8 check-in again 1-15 years
That it is. However if you bought 88e two weeks ago like I did you'd be 30% up right now.
4 minutes ago, HEKT1K said:
NZ booked
North Island tips welcome
Rotorua Canopy Tours, its a bit of a nature walk and a whole lot of ziplining with some very cute guides.
Waitomo Glowworm Caves, Abseiling etc
http://www.waitomo.com/black-water-rafting/Pages/black-abyss.aspx
Quad Biking Tour near Wellington
http://www.wellingtonadventures.co.nz/   We did the half day tour, spent the whole time wishing we did the full day tour.
Also if you're going with a bunch of mates, we did a White Water rafting thing somewhere near Lake Taupo which was a lot of fun.
30% of $0.04 is $0.012
well done fool. you made 1.2 cents
  • Like 2
Yeah but if you compound the profit and successfully reinvest, you could see 6 cents and so on. It's a bit of work but we weren't all born with the gift to connect motivated buyers with motivated sellers.
  • Like 1
Legend, thank you
Don't think I'll get down as far as Wellington, other stuff looks like a winner though
Not going with mates so may give the rafting a miss
19 minutes ago, HEKT1K said:
Legend, thank you
Subtle
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
