21 hours ago, Leroy Peterson said:
thnx m8. ill just wait for 88E to hit 18c (which should be next week).
in the mean time. Moh, buy these for the Stag.
http://page9.auctions.yahoo.co.jp/jp/auction/k221498156
i might go VLC stockies, redrilled to 5:114 and the lips and barrels machined to go 3p :P
I was looking at these for the trailer when towing to track days and staying in motel.
that and lock nuts on the wheels.
will stop opportunity thieves
When we left our kart trailers at the track on race weekends we had a steel bar that locked the wheels to the framework [emoji6]
what i say? announcement Friday....
...Alaska time.
DYOR IMHO FOMO TFG #raindance
also, i need dish like this in my life http://page24.auctions.yahoo.co.jp/jp/auction/q127501513
oreore_japan0001-img450x600-1472790059oc
Out of 88E for the now; the daytrader in me couldn't resist a $300 win for the day. Put a buy order in straight away to get back in lower and only 1/4 of it went through.
Pls no good news Monday
FYI - Went to Costco today. Saw they've now got "low profile" jacks in. They are $1 cheaper than the red ones, and heavier weight limit though the red ones are aluminum I believe
  • Like 1
1 hour ago, Jonnoo said:
i got the red one! Never seen yellow before
I hadn't either before today, though it's been 3-4 months since I was last there. They usually have the red ones on the end of an aisle but they were actually on the shelves this time so maybe they're permanent stock now?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
