10 hours ago, Leroy Peterson said:
Everyone seems pretty accustomed to the difference nowadays. Considering how many cars you see running them on the street anyway.
I think you're talking about all those folks saying they're running Semi's and then mention they have RS-Rs or KU37s lmao.
1 hour ago, joeyjoejoejuniorshabadoo said:
associated tyre did an alright job on mine many years ago and have a pit style setup so low isn't an issue
Funnily enough someone who works there owns an R34 GTT that I see when I drive past.
I went to them a few years ago to get an alignment for my car. I had the specifications as they were hard to find and the response I received was "thanks we'll work it out". Ended up getting the car back with the tune wayyyy off. They made my car look like one of those stance cars with the amount of camber added, was maxing out the camber bolts. Won't be going there again :\
14 hours ago, Leroy Peterson said:
looking at fb someone asks: " i was under the impression that when events are help at race tracks and the organisers have to organise the insurance (aasa etc) doesn't that cover things like this? " Which is a semi-warranted question, but also a bit ignorant.
Response: " AASA/CAMS insurance for is Public Liability + ambulance costs @ the track; it doesn't cover medical transport from track to hospitals and other medical expenses.
AFAIK...
Ambulance Costs are a separate component that goes into organising a track day, it's completely independant to the AASA/CAMS permits (Track Public Liability)... but having an ambulance present at certain tracks (pretty much anything high speed) is often a requirement of AASA/CAMS granting you a permit for the track day.
We pay the ambos to be on standby the whole day, and to be a first responder should there be an incident. If the ambulance leaves the track with a patient to take them to a hospital, the cost falls on the patient (thus, why you get Ambulance Coverage for like $45/year)...
I wonder what happens to the track day if the ambulance has to take someone away (even if some old guy is having trouble breathing in the pits and needs a ride to the hospital), does the lack of ambulance presence shut down the track for the rest of the day? I'd had to think of the impact for the club if the ambo was gone for an hour and there was a major crash at the track...
AFAIK...
Lack of ambulance stops PI and Broadford track days
lets talk ECUs
i was going to big single the sedan and go haltech and all that shit but since ive canned it, im thinking about going for a -5 set up now, and obviously PFC again.
i know chris is going to say PFC, so is matt.
yalla. discuss
lets talk ECUs
You missed the VWL disagreement last week.
It depends on what you're trying to achieve, and how tight your sphincter is. But I think we all know the answers to these questions, therefore you already know the answer.
1 hour ago, Mohsen said:
lets talk ECUs
yalla. discuss
Should have bought my big single sedan
The answer is Nistune OR the R34 plugin GTT ecu from Haltech. Has all the features you want and 0 wiring, easy to tune, local, etc. Hard to argue against.
wont work on the new car.
will ask the boys at RP and see what they reckon
How can two ECU's that work perfectly on a R34 magically not work on a new car?
But -5's are really never the answer for anything, so I'll assume it's a 26 in which case Nistune is the answer.
Also, -9's are the answer. Also there's probably a plugin ECU for what you're doing.
Seriously the only reason for PowerFC is "it already had a powerfc in it"
There's a 33R PFC in for sales section with hand controller for $500
Tune for $500 and you're done for less than the price of a Haltech
That's why people like PFCs
yeah might just go another PFC. wish i didnt sell mine, then again might just get a D jetro and run no AFMs
  • Like 1
wait, is -5's for the GTR or the sedan? whats happening with the sedan?
but seriously, just dont touch the GTR. leave it, let it appreciate. the less you drive it, the less repairing it will need.
now get some wheels for the stagea
http://page17.auctions.yahoo.co.jp/jp/auction/v467805801
1 hour ago, Birds said:
Better at having a hand controller? I don't think so
But I carry a laptop and can fully tune my car wherever I go, with better functionality than a hand controller :P
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
