4 hours ago, Mohsen said:
for the GTR, just gonna repair it and have a nice 330ish kw cruiser.
the sedan is being stripped and put into storage.
may come back soon, may come back in like 10 years, i dont know. nothing on the cards for it atm.
motor, front end parts and the nice interior pieces will go into the R.
Where you putting it in storage? Anywhere I can slot in a car? Will pay monies
28 minutes ago, Daz said:
Just got this from UK forums
"4th gear is the input shaft effectively. Select 4th and the input shaft is locked to the main shaft and drives straight through at 1.00 ratio - most efficient gear in the box, lay shaft is bypassed"
So stock 4th would be pretty strong then?
Yes 4th gear or whatever is 1:1 ratio in a gearbox is the strongest because 1. There is no differential in the ratio (a small gear turning a big gear or vice versa) and 2. No layshaft involved because it's bypassing it and going straight from input shaft to output shaft. You'll snap the input shaft before you lose 4th gear. When you blow another gear 4th is usually all you're left with to limp home in.
It's therefore the best gear to tow a car in (unless going up a hill and struggling in 4th).
A lot of kits only bother with the first three gears because you can't replace the 1:1 and 5th/6th are rarely used or don't see much stress in racing (only on straights). The number of 5th and 6th gears that get smashed from towing trailers/cars in them, however...
2 hours ago, Leroy Peterson said:
Jesse Streeter?
@luke gtr @Birds Now's your chance to have that camaro you've aaaaaaaaallllways wanted
http://www.carsales.com.au/dealer/details/Chevrolet-Camaro-/OAG-AD-13503676/?Cr=0
Hurr durr what should I advertise my car for...errr I'll add up all my receipts and then add 20 grand appreciation and 30 for the time I put into it, yer that's prolly a good price
Thanks very helpful.
So I may as well go the 1-3 kit with strengthened holinger input shaft?
As there is no aftermarket 4th gear then I may as well also retain the factory 5th as I don't really ever race upto 5th (speeds are usually way too high by then and I'm usually lengths ahead already :P
Edited by Daz
Pretty much. If 4th takes you to 220-230 and you're not going to see above that on the street (I hope lol) then the 5th will only be used on highways for fuel economy. You'll more likely be off boost when accelerating in 5th too, in which case no worries. If it doesn't cost much more for a replacement 5th gear then may as well do it while you're doing the rest, but if it's like $500+ then fk it I say.
  • Like 1
2 hours ago, Borci88 said:
Lmao its f**king not. Stop spreading rubbish. You wouldn't have to carry around a laptop to "fully tune your car wherever you go"  if you had a PFC instead of Nistune.
I don't "have" to. I choose to. And I have a haltech, fyi. With a PowerFC you're at the mercy of whatever happened at the tuner. That's nowhere NEAR enough to be confident in any tune.
Hand controller is a joke when you can interact with an actual ECU.
PowerFC, the official ECU of "Well, it was already there when I got the car..." or "I need something tunable and my stock ECU is not tunable". But if you're there, ANY option beats it out.
  • Like 1
Ahh a Haltech fanboy I see.
Hand controller aint a joke, you get a good tuner who knows what hes doing you dont NEED to touch ANYTHING tune wise. You watch the hand controller and read out 8 different sensors that are going on in the engine.
Have had a Nistune, now I run a PFC. Won't touch a Haltech, too annoying to tune, shit with stock CAS, don't want 8 expander boxes sitting in my foot well just to run a couple of extra sensors. If you could look past the internet fanboy and sales pitch of these ECUs, you would understand that a PFC does EVERYTHING you NEED it to do.
It doesn't do antilag, boost by gear, flex fuel, (boost, starting, timing, etc) have a MAP sensor, have a controller I can use on a damn PC...
It doesn't auto log while the car is running so I can go back and see what HAPPENED. It doesn't have 5 channel engine protection. Won't run a wideband (I think?) Won't run a wideband controller.
These are minimum requirements for an ECU.
Never had issues with the CAS on mine.
If you don't think a tune needs a touchup or monitoring then ...  well, lets say once you see it you can't unsee it or live happily without it.
Not needed but PFC PRO does antilag, Not Needed, Not needed in 9/10 cases, D-Jetro.
The only downside to PFCs is engine protection, other than that they do the job and they do the job reliably. You are KIDDING yourself if you think you NEED those features.
PFC = $500 + $500 to tune
Haltech = $2400 + $900+ to tune with all the features (This doesn't include the cost of the IO Boxes and paying someone to wire it all in)
Guess what, they both get me down to the shops.. and they both get me out on the race track reliably. Guess what I'll be choosing...
  • Like 1
That's great, but like I said - Maybe you can live without knowing. It doesn't mean it doesn't happen.
I use *all* of the features I listed, it has plenty more I don't, and any other major ECU will do this too (or more, like Traction control on Motec, etc).
They do the job. They can provide a tune to an otherwise untenable car.
Power FC can't do anything ANYTHING that another ECU can, and a lot of things provide more features than a PowerFC.
Your "not needed" is my "holy shit that saved my engine" or "useful diagnostic tool". There's no reason to choose a PowerFC over anything. Ever. Unless you got it essentially for free.
The argument can be made that the PFC is enough. It can't be made that it's better.
To get around my wiring drama I'll be using a r34 ecu + nistune but loading a stagea rom. This is due to stagea not having traction control which the r34 does....
Now I need to work out how to bypass ecu going into limp mode due to abs missing.
There's a bit of misinformation here dude!
For starters, you pay a tuner to sort out a tune for you. If you're not confident in a tune that you can leave it static / set and forget until you've changed something significant about the vehicle, then you need a new tuner who doesn't work on a knife edge and can allow for some variance. That extra 5rwkw is not worth it.
Hand controllers can actually do a lot considering what most use them for (sensor display/diagnostics). Having one is a luxury and not a necessity; no one is claiming it's the greatest thing since sliced bread, but it's very occasionally handy to adjust settings like idle without carrying around out a laptop.
Meanwhile you're pretty much slating the modern luxuries of modern ECUs as necessities and bare minimums when they aren't.
What really shuts this down is that you can interact directly with the ECU and tune a PFC yourself, easily. I have an FC Hako USB cable, which cost about $100 from memory, and sits in my glovebox. At any time I can plug it into a laptop and tune to my hearts content or log data. Minus flex fuel, which I don't actually need, there is nothing a Haltech or Nistune will give me over and above the PFC. The proof of this is that I've run one flawlessly for the last 5 years and "upgrading" the ECU would give me nothing but headaches and minus $1000-2000. It's dinosaur tech, but they got it right the first time.
Birds... you don't use the functions I use on a daily basis and require.
No tuner, Not Chequered, Not Racepace pump out tunes that can't be touched up and modified on the road. Maybe you're OK with a good enough tune that feels right. Maybe you're not like me and will look at graphs and change a fuel cell months after the fact because the AFR is out by 0.5 in a certain cell I barely hit. Cars change. I know what mine is doing and a fuel pump failing will never kill me, neither will a filter, neither will any of this. It's not the car will explode under load. It's ALLLLLLL the stuff that is NOT full load that you can DIY. Saving you tuning time, if you're in to that, too. Plus you get a car that really DOES drive like a factory car.
Trust me when I say your car will feel absolutely fine blasting down the street on boost at 13:1 AFR or 14:1 AFR.
Ever drive the car and have a strange miss? Going back in time and seeing what happened is un-losable once you can. Hand controllers are great, but a laptop is better. Learn your car and your setup and within a short period of time you'll just be borrowing the dyno instead of being at the mercy of someone tuning your car for you. Knowing wtf they are doing and why and how is really quite rewarding.
But I do. Even not having access to flex is an instant game breaker. Like it could do everything EXCEPT flex and yep, sorry, game breaker. These are features that I live and use all the time. Not everyone does, but I do and I would certainly never go back. Cold starts across an entire year? Not a problem. If it is a problem, you can just sort it out.
The power FC is a basic unit which can give the same features of essentially a factory tuned ECU.
I really, really, like the extra features and all I've said is if someone said "I don't have an ECU, what would you buy?" a PowerFC is never on that list. It's just not. It's the same reason you wouldn't suggest someone put a T40Z or HKS T51R on their car in 2016, but you wouldn't necessarily destroy for no reason.
More misinformation man...
I can change my RacePace tune myself and have done so...while driving out on the road. You can mess with the fuel cells if you really want to. You say a laptop is better...great...I have that with the PFC, I can data log and tune with it why are you saying you can't? Besides that, no, I haven't actually had a strange miss...my tune is awesome cause I paid a professional to set it up for me.
My car feels like a factory tune, perfectly so. It's what I paid Chris to do for me.
You're going OCD on ECUs and blaming the PFC for having shortcomings it doesn't actually have.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
