12 minutes ago, Birds said:
More misinformation man...
I can change my RacePace tune myself and have done so...while driving out on the road. You can mess with the fuel cells if you really want to. You say a laptop is better...great...I have that with the PFC, I can data log and tune with it why are you saying you can't? Besides that, no, I haven't actually had a strange miss...my tune is awesome cause I paid a professional to set it up for me.
My car feels like a factory tune, perfectly so. It's what I paid Chris to do for me.
You're going OCD on ECUs and blaming the PFC for having shortcomings it doesn't actually have.
I'm saying I use the features things better than the PFC have. Your tune "feels" right but there's no way you can perfectly setup a car in a few hours, ever. You can get 90% which is good enough for 99.9% of situations, but not 100%. I change fuel cells all the time (well not all the time, but certainly have in the past after changes are made, on a different mixture of 98/e85 which wasn't done on the dyno, etc.)
How are you gonna know if an injector is slightly failing? Fuel pump is starting to let go? Fuel filter is clogged? You may not care but I sure do and I have that ability. You won't know till you melt a piston. Maybe your components will never fail. Run 2 pumps and ONE dies? Oil temp too high, water temp too high when you're out on track and not *really* looking at Gauges because looking elsewhere? Oil pressure starting to get a bit thin at high RPM? etc.
Logging is great, but automatic logging to the device AFTER the thing you wanted to log has already happened (i.e, don't have to turn on logging first and then go test something) is a godsend.
The powerFC enables you to change fuel maps and timing to allow for mods. For a setup like yours Birds, it's enough, and it does what it does, well. But once you use more than that or think "that'd be useful..." you would never go back to one.
http://www.theage.com.au/victoria/pregnant-woman-attacked-with-hammer-by-four-masked-men-in-terrifying-noble-park-robbery-20160915-grhi9t.html
All three men are perceived to be of African appearance.Their car appeared to be lowered and sounded as though it had a turbo engine.
12 hours ago, Birds said:
Where you putting it in storage? Anywhere I can slot in a car? Will pay monies
you know russman? he got storage in ringwood. dont cost much.
lowered and turbo engine? racist.
oh, falcon G6E turbo........ unpatriotic
Birds, Moh and Borci all got GTR's.... odie, greg, johnno, pat all got skylines. only one evo around, and its pretty much for sale.
Balance has been brought to VWL. now just need balance to return to oil prices.
Birds, use 88E profits to make your GTR look better (offsets arent the strongest, but dat dish. also a bargain for classic 5 spoke wheels. mental money for OZ or Koenings):
http://page3.auctions.yahoo.co.jp/jp/auction/c553379175
were like the A team, But really gay and soft.
we should do a vwl bbq, seriously.
my mate rogercordia will come too
I'm not certain that kinkstah is the same guy who's car is never on the road, and when it is, something dies or is about to die... What I am certain of is that there is a thread somewhere on this forum, dedicated specifically for people to discuss their cars more than they drive them.
Go there
We should do BBQ, i wonder if Toby will have us back? :P that was the last true vwl gathering and it was awesome
Yeah saw him towing his race car from Ringwood once actually
5 hours ago, UNR33L said:
Birds brah, https://csgosquad.com/ranks
We need 3 more for VWL cs:go team, who is 'the l337 pwn3rs' here?
Yeah I've seen that rank distribution. It's garbage tho, proved that last night top fragging deathmatch even if you weren't trying. Will create a smurf account either for you to level up or for you to play in my rank and help boost lol
Respawn LAN end of October. Form a 5 man team. I can shoot things but I'm useless compared to the veterans.
Need to reclaim my title on Wreckfest and asetta corsa.
My friend has started a website for oz teams looking for members: www.rekruitable.com
Already have rarish wheels sorted, a mate is holding onto them for me...no point buying until car is done.
88E profits have gone into house savings. Bout time I grew up and bought one lol
lol... and you have such a good record of not breaking things
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
