You guys happy paying 75% of my premium for 25% of the agreed value and not being allowed to drive anywhere...?
Of your premium maybe... Mine is/was 1100 full comp with limited use and only I can drive it. I'll take the $500 laid-up when it's off the road thanks...
Trying to get the agreed value over $10k for a pulsar is not easy.
With a falcodore Ute, they know they can void the claim when they find bald tyres with steelies on the back and 22" wheels on the front and no suspension in the rear.
16 minutes ago, UNR33L said:
Sundays ride up Mt Baw Baw was f**kin' wet, had to wait 2 hours for Ambo too after a mate broke his anle:
Don't wanna be that guy that says I told you so
But did this happen 2 days after our argument over jet skis vs supermoto, where I said too many of my mates have done their ankles and collarbones you said you hadn't seen it yet?
Jus sayin ;)
Hope he recovers well; what did he high side on? Brake lock up or throttle close?
Jus sayin ;)
To be fair, he rocked up on dirt bike knobbies and was sliding around corners on purpose haha.
If he had his Supermoto tyres on wouldn't of happened - yeah doctors think 8 weeks.
HEADS UP
had a call from 0423-802-827
sounded like a pleasant guy from the AFP association.
anyway, ran me through a few advertisment deals etc.
wouldnt email the packages for the accountant to see, nor would they leave a name or number.
looked into it further and its the same number that claimed they were from the sherrifs office and i had to pay $500 via credit card or ill get arrested lol
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
