I found the AD08R to be absolute garbage in that last turn trying to get any power down (lowered the boost as much as possible and had big issues)
That said, can confirm am noob driver. My suspension is possibly f**ked though, but 5kg front and 4kg springs at near stock ride height is pretty fkin boaty and non track optimal, like everything that I haven't near immediately changed after actually trying to use it.
Birds, turns out that "Catch can" was actually pretty much venting to the engine bay as that's where it was disconnected (back to the intake, at the intake) and just pissing oil everywhere. Bought a replacement with actual baffling that will actually be setup actually correctly to actually catch oil (or at least put it it back into the intake and not into the engine bay), and actually get some actual tyres for the next time. (i.e, Nankang AR-1)
Or just cheat and get a GTR for those slow corner exits
Also that chaser was parked literally next to me. Was a nice guy!
Greg, I followed your car down the main straight, into turn 1,2,3,4,5 and partly down the back straight and I thought it looked to be handling quite well. As far as traction out of the last turn, with the amount of power and torque you have on tap, throttle control is the key and yeah the biggest r spec tyres you can fit would be a good f**ken idea.
19 minutes ago, admS15 said:
Why did he need to get towed. What happened?
started blowing huge amount of smoke at end of the main straight so shut it off.
turned out to be a minor thing, over filled with oil
  • Like 1
I had turned the boost down so I was running a fair bit less than 415, more like ~320ish but the delivery is still much the same and first time ever out on the track in the thing, I almost put it into a wall on the back straight coming on power too, so that was why I went home to get the laptop to turn that boost down before death. Obviously a stall converter not the easiest thing to feather but it's 'doable' with some restraint.
It did feel rolly and sloppy as all hell, but maybe that's what everyone is dealing with and I should just learn to drive :D Sure was fun though.
1 hour ago, UNR33L said:
so where's the best place to buy AD08s? seeings as I need new rims anyways - dont they have a buy 3 get 1 free thing atm?
I feel like Hamish and me were the only ones that liked the NT05s
Dunno about best but Traction Tyres (inb4 Greg) sell them. Not cheap though. I got mine for $220 a corner a couple years ago but they were 2013 production so cheaper.
You don't have to go AD08s, RS3s are probably better value, but yeah much better options out there than NT05. Think Ric liked the Nittos too.
Yokohama buy 3 get 1 free special atm doesn't include ad08, only some shitty suv tyres. I got my ad08 through bob jane of all places, was actually better priced than traction tyres. I noticed the tyre factory advertising RS3 last week on ebay for 269 for 265/35/18.
Given I could plant 1st and 2nd on the street without breaking traction (without warming them up) in a 320rwkw car with 320rwkw at the wheels I was damn impressed.
edit: 320rwkw
Edited by joeyjoejoejuniorshabadoo
to add more 320rwkw
FWIW I found no real huge difference in NT05 and AD08R in terms of grip for the street. Housemate with RS3 and AD08R noticed no mega difference, maybe the AD08R lives a bit longer due to the higher cost so you aren't swapping as much.
No back to back laptime data etc though, all by that seat feel.
Been looking at RS3 as well, as usual barely any around in the sizes I want, sent a few emails this morning for some quotes, most with this response:
"Sorry they have no stock of either sizes. I have checked a couple of sizes close to the size you have asked for and stock very limited."
Seems to be more Invo / NT05s
http://www.ttf.com.au/#/shop/tyresbysize/245-35R19
Edited by UNR33L
edit: 320rwkw
This to me isn't so much evidence of NT05s being good but hub dynos being liars
2 minutes ago, UNR33L said:
lel
anyone tried the  Michelin Pilot Super Sport ?
tried them on a mates car and wasn't that impressed for the $$$
not bad, not great
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
