Just now, Birds said:
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
and if I remember correctly he whinged like a bitch about road noise for like a year
3 minutes ago, joeyjoejoejuniorshabadoo said:
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
it's common knowledge that heathcote speed trap isn't accurate, mine was a few mph higher than all the other tuned 5.0s too
your move :P
edit: it's true, NT05s were noisey af
Edited by UNR33L
Which is why I always maintain it being undervalued
That oil price will inevitably be sky high again one day as the finite resource diminishes and even unconventional plays become worth a truckload. The market hasn't factored this in yet, hence minor OPEC shit gives a small push. If the rest of the world is banking on renewable energy offering an oil solution and you hedge against it...correctly...you'll be winning.
370 sets would take a while to get through
unless you had a 370kw 370z
  • Like 2
31 minutes ago, joeyjoejoejuniorshabadoo said:
INVO's are probably better street tyres for your power level though - will last like 5 times as long too
I did still have the skyline when I bought them
glad i didn't get a chance to fit them and gift the new owner a fresh set
  • Like 1
Not for a few more years at least. The OPEC announcement won't change a whole lot it just restored some confidence that something can be done to hopefully limit the Saudis and Russians trying to undercut the Americans. I think the Saudis are in trouble soon...
But this unconventional thing is a double edged sword. The more that is found and is profitable, the less finite the resource is. So looking 5 years down the track, I don't think itll get back to $100 a barrel. Everyone involved is looking to retire before then.
As for undervalued... Otto energy is exploring in 3 different locations, their great bear section of Alaska is next door to 88e and is further ahead in exploration but worth 4.5cents still. Due for some results in dec-jan. If it's not amazing news 88e will take a big hit.
12 minutes ago, HEKT1K said:
Move on pls Birds
My priorities have changed
I'm sorry that the theft of your vehicle hit me harder than it hit you
#insurancejob
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
