well its taken a month, a bunch of headaches and more questions than answers, but my telstra cable is finally setup.
comparison:
Is it worth the trouble and an extra $10 a month? if it can maintain over 10mb/s 24/7 then yes.
The provided modem/router is pretty useless... wont tell you speeds or chart usage or even let you change login username (wtf, stuck on admin forever). Now just to figure out if I can use my Fritzbox for Wifi only...
  • Like 1
On 10/7/2016 at 8:32 AM, Leroy Peterson said:
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
What Department?
comparison:
This image is showing 13Mbps, not 13MBps...
8 Megabit = 1 MegaByte
The plan you are on is a 30Mbps plan and you're achieving 13Mbps.
Either there is a problem with your connection or there's congestion in your area at the time of testing... Try again later and see if it hits the full speed.
This is what a 30Mbps plan should look like:
100Mbps plan should cap out at about 115... Either way you're not likely to see the difference in the two speeds unless you download a lot of big files (not talking about torrents), or need additional upload speed (the 100Mbps plan caps out at ~2.4Mbps up instead of ~1.2)
So is this shit? Never been impressed by our internet speeds and we have had this Optus Cable for the last 6+ years.
Steam displays speeds in MBps... 2.9Mbps x 8 = 23.2Mbps = edging closer towards your 35'ish maximum.
Try http://speedof.me/ and see what result that spits out... I find its a bit more accurate, and doesn't require flash either.
Also when testing, make sure nothing else on your network is download anything... and don't be on wireless if you want an accurate result.
Blow me pat
  • Like 1
Thank f**k someone knows the difference in abbreviations
Felt like I was taking crazy pills
I mean what the shit is this Patrick
4 hours ago, Rekin said:
12.5mb/s is 100mbps - that's a good speed. Can't get faster on cable.
Getting stooged on your upload maybe? Mine is 1.15mbps on ADSL2, but only 12.5mbps download
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
