1 hour ago, joeyjoejoejuniorshabadoo said:
What a load of "poor-me" conservative facebook comment section horse shit.
Let me guess, the left media is opressing you too by holding back the silent majority?
That wasn't at all what I was suggesting, but since you brought it up
Something like 96% of disclosed journalist donations have been to the Dems...if you don't think the US media have some left minded bias heading into this election...you would probably be a delusional and/or ignorant leftie too.
Even westboro baptists, who are about as radical as conservatives get, do not hold a candle to the obscene shit all the social justice warriors pull off. Pretty sure the blacklivesmatter crowd aren't gunning (pun unintended) for a Trump win...
another TV2 announcement.
and things looking good for 88E. might be a few things here and there, but the remaining info on the seismics are still yet to be completed. Then drilling from Otto/Great Bear Jan next year, then drilling of IW2 in Feb... if things are looking good by then ill probably pull out most of my shares (a whopping 30,000 or something).
The coming weeks might be a good time to get in if anyone is thinking about it. Thats just wot i think. Unlike Birds' aggressive marketing tactics.
So turns out wasnt bed bugs. My skins has weird issues with the sheets they use (or what they wash them with). I googled info on bed bugs the other day and saw the bites look different and were no patterns or specific areas of bites. Slept wrapped up in a random blanket and was less itchy, then i asked them to fit normal bed sheets and slept on them. So far so good.
Crisis averted.
In the mean time my arms/hands/neck/head is itchier than mohsen's crotch.
not how I would want to go...
"a dead man found stripped and bound to an airport bench with a slice of ham on each buttock and his genitals in an open tuna can "
http://www.news.com.au/lifestyle/real-life/news-life/man-found-dead-with-genitals-in-open-tuna-can/news-story/2157aaa5f872106d01fa19d9d3b46d7e
http://www.theregister.co.uk/2016/10/28/blood_donors_privacy_anaemic_after_red_cross_data_breach/
When will we get laws for mandatory breach notifications..
till the info comes out in the public nothing is done.
So AU companies do a half arsed version of security.
1 hour ago, UNR33L said:
anyone going to SNL tonight on eastlink BP inbound? should be a good turnout given the weather
What's that? Car meet I assume?
Live 5 away now lol
1 hour ago, Leroy Peterson said:
I can go, only 5mins away. will need to charge battery on Gloria lol.
Live 5 away now lol
There'll be cars there from like 4pm-11pm I'll be there about 6pm and usually stay an hour or so
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
