Hillary paying 1.40, good time to jump on.
Sounds like springy motors' dyno is struggling for tie points with the pulsar... maybe will have to employ some VL tactics and just get a bunch of fat people to sit on the front of the car.
14 minutes ago, Leroy Peterson said:
thanks Martin but sounds like its all done and dusted haha. i got the final power figure but i dont want to say anything till ive driven it.
So whens the next track day? :)
