well its costing me nothing to sit here and wait.
speaking of waiting... TV2 back online. not much of a drop after being halted for 6 weeks, might be a good time to jump on. but, following my logic. probably a good time to sell.
family christmas on sunday. then both parent's birthday 2 days after. havent got anyone anything. only in melbourne tomorrow and sunday. balls. might organise some people and take dad to Little River shooting range. reading through reggs and its nowhere near as flexible as it used to be. if you're not part of the club (licensed or not) theres very little you can do. pretty shit. how do you expect to get people into target and trap shooting? .22's at sandown gun range?
Sandown have done the opposite and made it easier over the years. You can rock up without a licence and be shooting as they're watching over you, or if a licenced shooter takes an unlicenced shooter along they'll leave you to do your own thing.
You still can't staple pictures of people to the timber though...
On 12/15/2016 at 11:47 AM, Birds said:
Whilst I still think 88E will slump again in the short term, the current news is great for long term holders
Reading between the lines, you don't bid on another 150,000 acres of land if there's nothing special under there...
I think it's illegal to be this accurate with predictions
If only 88E could be short sold
2 hours ago, blah_blah said:
TLDR
So whats changed with torrents?
Still safe to download?
Still safe to download torrents, but they are trying to block websites that give them to you like the pirate bay etc. Basically nothing to worry about as there's a million other sites.
  • Like 1
34 minutes ago, UNR33L said:
man up borrow and put 100k on it :P
Don't quite have 100k or like my chances of getting a loan secured against a spec stock lol
Watching gopro footage from yesterday at PI, sound works fine on the laptop.. tried streaming from laptop to WDTV, sound works for a few seconds then nothing, video is pretty laggy too... so moved the file to the network HDD and played through WDTV (like I do with all shows/movies) same thing happened with the sound..
Am I missing something (apart from the sound...)
Sounds (pun intended) like a bandwidth problem, I'd suggest editing the video down (or compress to 720p / lower bitrate) to a smaller file size it sounds like it's massive file size? You can use the GoPro Quik software for desktop/laptop it's pretty easy to use and free.
Edited by UNR33L
Yeah it was filmed in 2.7k so 3 something gb file... Just strange never had an issue playing 1080p movies over my network..
I've got the quik software, I like the gps features being automatically on videos, speed etc, but the software itself is far from great. No play controls when in full screen mode (unless they need to be turned on somehow?) need to press play everytime after searching forward or back in a clip... Little shit but pretty annoying considering its key job is to play videos..
Don't forget 2.7k has almost double the pixels of 1080p (about 1.6 million extra pixels or so) and there's other more complex things at work here too like bit rates.
And yeah the Quik software is a bit shitty / fiddly I pretty much only use it for the GPS speed gauges and crop the clip I want out. Have you got the Hero 5? I got one the touch screen is pretty sweet. I just run 1080p at 60FPS wide lense, gives dat real life quickness feeling.
Yeah hero 5 black.. Touch screen could be better but it does the job.. I was filming in 2.7 for the first few sessions but battery life was pretty bad so switched to 1080.. Still had to charge between sessions because it was dropping 20-25% per session... Not a big issue when you have power available though.
If you crop a clip can you make it so the speed etc still shows up in other players? Haven't tried that yet but I'm assuming after you actually make a clip in quik as opposed to just watching the videos in it, the gps data stays with the new clip?
2 hours ago, Leroy Peterson said:
Sandown gun range is like .22's and pistols only. Group I'm organising has shotguns and bigger rifles.
Go to carrum downs for shotguns / clay
Update the firmware on the gopro through the app on your iphone/android - it fixed my shitty battery life issues.
Yeah turn on the gauges, then cut the clip section you like, click save, give it a file name, and done - once you open new clip it'll play with gauges with any video player
  • Like 1
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
