3 hours ago, viper2002 said:
Anyone know how I can get in contact with the SAU Secretary? Need to get a confirmation of my membership for a track day tomorrow but it's hard getting an e-mail replied to...
In response to the email you sent last night, yes you are a member. Secretary is sending you info tonight.
Hope your track day is a great one :)
Thanks Tony, e-mail was received. Track was very fun :)
  • Like 1
so i buy one of these USB to DB25 parallel cables: https://www.jaycar.com.au/usb-to-parallel-bi-directional-cable/p/XC4847
plug it in, under Device Manager its listed in USB controllers: USB Printer Support. The software I'm using needs it to be a LPT port.
The internet has some solutions for people using old software with new printers, so ive followed them:
Create new printer. Assign it to USB Printer Support. Right click on it and go to Printer Properties. Select LPT1 port. I try to send file with software, software says did not send.
I tried enabling Print Pooling and selecting both LPT1 and the USB Printer Support port. Still does not send.
Then tried creating another printer and assigning it to Virtual USB port001, in printer properties, select LPT1 port. Files does not send.
Any IT folk have any suggestions? the software just sends a basic text file, its not going to a printer.
8 hours ago, emts said:
Oh chatted to a EPA guy on the weekend.
asked about the car testing currently.
Didn't answer the question, but did say he uses the building where they test as his car park everyday.....
Why the secrecy does he believe he is in a role that is top secret like Area 51?
Is he implying that the testing is active hence there everyday? Or that his team has taken over the area and they no longer test? :/
Is he implying that the testing is active hence there everyday? Or that his team has taken over the area and they no longer test? [emoji32]
If he was implying it was business as usual then there wouldn't need to be so coy... sounds like the intake of cars is slowing down?
Someone drive past the moorabbin workshop & have a look at the number of cars outside?
55 minutes ago, emts said:
implying the place is only used for car parking.
never going to openly admit that they are not testing cars.
top mount external gates here we come
These aren't RWC safety items right? or Wrong? :/
been keeping an eye on SLX shares since November. stable, no activity. During christmas break goes from 39 to 50c. then stable for weeks. suddenly hit 70c today. :( oh well. we cant all be like Ash Ketchum.
yeah but you would have had to buy 1,600,000 of them to be worthwhile anyway
Tempted to go Winton this saturday they've got a bike day, wonder what times I could lay down with the bike
$200 doe
Made redundant last week, rip
#ITlyfe
Edited by UNR33L
Yeah really small (3 of us total) and basically lost a couple of big ish customers over Christmas / New Year due to them down sizing or cutting cost, selling business etc.
So back on the job hunt, got a few good leads already which is awesome.
Paid out but not much (only here for about a year)
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
