so customer shutting down or just letting off a few ppl (if so how many left)?
we just halved our team prior to Christmas as well, lucky all dropped into a role straight up, so there a bit of work out there.
best of luck, and if I hear of anything will let you know.
M
Any of you IT kunce know how to fix this? Was at Phillip Island for a track day yesterday, was trying to download lap times from my HM dash to my laptop but kept getting this error
20170125_124103.thumb.jpeg.4c4541709d432
Googled it and it said possible fixes are reinstalling the software that's giving the error.. Did that, no change.. Downloaded latest firmware and usb drivers from HM, HM firmware update software gave me the same error when trying to upload the firmware to the dash...
Tried to update drivers through windows, drivers info through windows says no driver installed, selected the folder with new drivers then got this error..
20170125_124241.thumb.jpeg.f7dd28dbb2ae9
Next step was smash laptop and dash in a rage, but I've held off on that thus far..
And recovered.
Taken from Melbourne Airport while I was away, dumped in Reservoir. So I woke up one morning with a message from my folks saying "Oh yeah, the police just called for you..."
*sigh*
sfc /scannow says everything is fine.... so everything is fine, but nothing works. :thumbsup:
2 hours ago, Odium said:
And recovered.
*sigh*
Surprised you parked there after Leesh's Skyline got nicked from the airport and dumped in Meadow Heights
Never again - we uber there now.
Obviously a bunch of regulars poking around the airport stealing cars. And security there pretend like it's a rare / never happens occurrence...
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
