Everyone creaming their pants on facebook over a VF HSV Ute for $90,000.
Even comes with an aftermarket super charger and 2 speed power glide. Great for towing a jet ski.
500kws and custom drive shaft... What is that, like 100kws more than factory?
I think the utes had 340kw only the GTS sedan had 430kw
Still slower than a tuned GS, funny when the ford GT with '350kw' made more rwkw than the 430kw HSV haha
Edited by UNR33L
My mates got an aftermarket charged ve gts, think the kit was around the $20k mark.. Makes 390-395rwkw I think he said... Didn't sound too impressive given the ls3 in his car was advertised as 317kw, 320 in mine... But mine with exhaust tune and cai are making around 280rwkw.. That's a '375' kit... 100kw loss sounds pretty high to me but maybe I've been out of the game too long..
Friend bought a property almost a year ago. single not-very-significant-income. House came with tenants, decides to let them stay instead of move in (sick of living at home, but who says no to rent).
He knew the tenants were filthy, no screening process because existing tenants (how does that work?). Not surprisingly they pay rent late, lately not paying at all. Real Estate doesnt notice, so he emails the agent. Few weeks pass, agent says "sorry lol been on holiday, whoops, lets get this sorted". Goes to the Tenancy Tribunal people and sits there waiting in queue.
Then talks to me about plan to use equity to buy another place in the near future. Have fun with that. meanwhile, miserable at parents place because sibling had a baby in a trifecta relationship (VWL-worthy SJW story that one) and the bread-winner wasnt a biological parent so when shit went down the parents got kicked out. Funny, but not funny.
We're still waiting on that trifecta story Liam.
1 hour ago, Count Grantleyish said:
All I know is Leigh needs less whining, more whoosh noises from his taxi.
Waiting for compound turbo kit to be available, they make about 1000rwhp with ease stock engine :) turbo sits under car haha
Just get two big ones by tonight Harry.
  • Like 1
A while ago I was googling to find the biggest/best quality CRT commercially available. and its like this 30" or something 4:3 behemoth. tables needing extra support to hold it up etc since it weighed in at like 40+kgs
Obviously older people and collectors wanted them so they fetched about $600 but no one ever wanted to cough up for postage (why are PC nerds usually poor? lack of career drive from disinterest in work? poor social skills to leave good impressions? poor body odour?)
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
