1 hour ago, Birds said:
Truly. If you don't care for location then you're gonna win big as far as buying a house and getting good value for it. It's astonishing what even a suburb across will do for cost. City is shit, unless you're 20 years old and going to nightclubs I can't fathom why people like living there.
This, for something similar to my property literally just a block down the street or further is at least 100k on top of my one just because of the different in suburb.
Hang in there, gentrification and all :thumbsup:
  • Like 1
I don't like Melbourne traffic irrespective of where it's going to or from.
Is it because there is lack of roundabouts for you to test the handling in Fiesta?
45 minutes ago, TiTAN said:
Yes. Also all the speed cameras everywhere and the whole 3km/h thing.
That's true.
Although it's 2km/h thing now.
2 with radar 3 with speed camera
Unless something's changed
Last speed camera fine I got was 2km/h.
That was maybe 2 years ago or was it 3?
1 hour ago, Leroy Peterson said:
Melbourne is a drive through the countryside compared to Sydney.... What a shithole
Give me NSW's 10% tolerance over here with 2km/h any day.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
