I want to get out of technical work and go into an I.T PM role before becoming a 'senior' don't think I've got it in me to continue down the tech path forever.
No one wants to listen to a 27 y/o boss them around though, I still gotta do some courses too to get in the door
Anyone can warm a seat for 10-20yrs and claim it as 'experience', it's what you achieve in that time which counts. You could achieve more in 5yrs than someone who ticks-thru 20yrs.
If your time spent has provided you the capability to perform the role don't write it off due to a number, be it age or #yrs working.
If you can prove your worth now to your direct-reports rather than falling back on what you did in the past, you will come out with respect no matter of your age.
  • Like 3
Try telling that to HR who filter the applications and weed out the ones who don't "meet" the requirements.
Or trying to get through recruitment agency word search filters.
All of whom don't give a f**k about references or achievements or milestones.
  • Like 1
Cover letter most important^
If you quantify in words your experience due to the quality of your work and level of involvement, you'll easily shoot over someone who says they've been in the game for 10 years but can't put into words what that means because they've warmed a seat and never done anything exceptional. Time of experience is also easy to lie about and good HR managers know this.
Time is also generally correlated with experience even if there are outliers like go getters and seat warmers, so you need inventive ways to be considered over the others.
Also, sif work for a company that purely values quantitative experience over quality...that's a sure way for your hard work to result in someone else's promotion because they're "overdue" for it / are next in line...consider their filtration of you a filtration of them too.
  • Like 2
True that, it's more me not getting off my ass and doing a course or doing something different to side step down the management path rather than technical.
Plan has always been do technical stuff till about 30 so I've got a solid 10 years experience then re-evaluate what I wanna do in my 30s career wise.
I know I'm listing numbers but I dunno, in IT seems like everything changed once I had 5 years experience under my belt, that could just be like you said by achieving more in that time than others with 20 yrs experience.. man some of these old guys have NFI how shit works..
Edited by UNR33L
12 minutes ago, Leroy Peterson said:
1999? I remember that thing.
The Matrix, Y2K, Red Hot Chili Peppers.
pls
The matrix confirmed the year was 2199 and 1999 was simply a construct of the machines, Y2k was in 2000 and the Chilli Peppers peaked in 1991 with the release of Blood Sugar Sex Magic
1999 was all about Futurama
26 minutes ago, joeyjoejoejuniorshabadoo said:
pls
And Hard Kandy
Just got a gas bill more than 3x of any bill in the last 12months, the charges go all the way to step-3 off peak.
Only gas appliances are heater and hot water. Heater is disconnected electrically and was serviced in winter. I was away from home 4 nights a week from Jan to Feb, then overseas for a month.
I'm reading that sometimes gas companies to 'catch-up' bills if they get their estimation wrong?
I'll check the gas meter when I get home, but if the figures are similar, ain't shit I can do?
Went from 27MJ a day to 147MJ a day. No leaks that I know of...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
