I guess most amateur drift cars break shit so often they don't get to drift regularly. But if it's been drifted it's probably pretty f**ked anyway.
Can't win. Lesson: drifting is bad mk.
There's the arugment that a car is tracked often must have been setup well/is reliable/has been looked after and used "as it should be" etc.
Vs a 25 year old car with 2,000kms on it.
well im working away from home for the next 4 months. Better hand over some cars to some workshops to get stuff done.
need eastside Auto transmission (or decent regular mechanic) to do some auto box work on the gloria. fix minor leak, replace small gasket, swap oil and see if it fixes sluggish shifts. greg?
Edit: booked in at Knox Automatics.
Knox is good for east side, they just don't like the 34 because.... I don't know? For servicing and general stuff I'm sure the'll do it just fine. Whether it will fix things is a different story.
Asking for a custom transmission that holds 500rwkw different story again!
I got mine done by DTM Autos out Westside, as in Geelong. Would also recommend for general auto stuff but yeah.. Geelong is not within what most people consider "acceptable travel".
I didn't, mine is a PCS2000 controller/ECU.
Probably has similar features. Though a plug and play solution would be great, though my brain is curious to know how exactly it's plugged and played into an ECU when the pins controlling the auto on a GTT are ... plugged into the Engine ECU...
Mine is wired in, but the truth is that there's only ~10 or so wires that needed to actually be wired in.
Also, WTS.
Gonna need a car trailer with upgraded leaf springs.
Transporting a dead hooker on an open car trailer is a poor decision. You need to use an enclosed one, he didn't mention that in his request and that could come back to bite him hard.
2 minutes ago, TiTAN said:
What time is a good time to question it?
trick question...never ever question it, unless you want a headache
Just chuck a car cover over it...or if it was a dude chuck a sail boat cover over.
  • Like 1
THIS is along the lines of what I was thinking...
http://www.dmhperformance.com/photogallery.htm
f**k varex. Thats how you do an exhaust valve. and you can add piping to it if you want
That's the kind of thing I told you to get pages back.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
