I guess most amateur drift cars break shit so often they don't get to drift regularly. But if it's been drifted it's probably pretty f**ked anyway.
Can't win. Lesson: drifting is bad mk.
There's the arugment that a car is tracked often must have been setup well/is reliable/has been looked after and used "as it should be" etc.
Vs a 25 year old car with 2,000kms on it.
well im working away from home for the next 4 months. Better hand over some cars to some workshops to get stuff done.
need eastside Auto transmission (or decent regular mechanic) to do some auto box work on the gloria. fix minor leak, replace small gasket, swap oil and see if it fixes sluggish shifts. greg?
Edit: booked in at Knox Automatics.
Knox is good for east side, they just don't like the 34 because.... I don't know? For servicing and general stuff I'm sure the'll do it just fine. Whether it will fix things is a different story.
Asking for a custom transmission that holds 500rwkw different story again!
I got mine done by DTM Autos out Westside, as in Geelong. Would also recommend for general auto stuff but yeah.. Geelong is not within what most people consider "acceptable travel".
I didn't, mine is a PCS2000 controller/ECU.
Probably has similar features. Though a plug and play solution would be great, though my brain is curious to know how exactly it's plugged and played into an ECU when the pins controlling the auto on a GTT are ... plugged into the Engine ECU...
Mine is wired in, but the truth is that there's only ~10 or so wires that needed to actually be wired in.
Also, WTS.
Gonna need a car trailer with upgraded leaf springs.
Transporting a dead hooker on an open car trailer is a poor decision. You need to use an enclosed one, he didn't mention that in his request and that could come back to bite him hard.
2 minutes ago, TiTAN said:
What time is a good time to question it?
trick question...never ever question it, unless you want a headache
Just chuck a car cover over it...or if it was a dude chuck a sail boat cover over.
  • Like 1
THIS is along the lines of what I was thinking...
http://www.dmhperformance.com/photogallery.htm
f**k varex. Thats how you do an exhaust valve. and you can add piping to it if you want
That's the kind of thing I told you to get pages back.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
