f**k me the ATO and MYOB run some shit programs.. never seen so many poorly thought out applications and poor designs.. 90% of our customers are accounting firms so this is great for me.
Well exactly - what happens when you reach the peak of perfect design and have to improve on it, e.g 90's cars. You end up creating horse shit and trying to pass it off as better, e.g ugly ass cars of today.
Bring back HTML websites with frames. Frames were revolutionary.
  • Like 2
It's like loading two pages on one web page?!?!? Magic
I think I'm going to quit all my hobbies and take up Shogi. then I'll eventually move to Taikyoku Shogi.
https://en.wikipedia.org/wiki/Taikyoku_shogi
250-odd different moves among the 400+ pieces on your team. Would take a few years to learn, but im sure it would be worth it.
88E should finish strong today being a Friday and expected spud is on monday. Might put a sell out today for a few thousand shares at 5c and see what happens (on second thought, its not worth it)
Given the lack of volume these last few days I think a lot of people might sell out early next week.
I'm guessing the ridiculous concept drew you in but this was the nail in the coffin
Because the game was found only recently after centuries of obscurity
  • Like 2
Volume dropping off and spud being a milestone non-event, I'd be very surprised if it didn't sink hard over the next two weeks. Would be selling now.
Only thing I see bolstering the price up is if press releases get picked up and increase attention for the operation.
On 19/04/2017 at 10:50 PM, Birds said:
Someone sent me this recently or posted it on here a couple months ago...they are back on it.
fuck me he's a sad little cunt
On the plus side at least he's not on huge dollarydoos...
Victoria Police salaries[55]
Rank Increment 1 July 2016 1 July 2017
Superintendent 1–8 $146,257 - $171,580 $150,279 – $176,298
Inspector 1–6 $129,428 - $143,711 $132,987 - $147,663
Senior sergeant 1–6 $109,308 - $116,370 $112,314 - $119,570
Sergeant 1–6 $97,557 - $106,315 $100,240 - $109,239
Leading senior constable 13–16 $91,119 - $95,573 $93,625 - $98,201
Senior Constable 5–12 $82,399 - $90,217 $84,665 - $92,698
Constable 1–4 $63,757 - $70,968 $65,510 - $72,920
Recruit 1 $46,409 $47,686
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
