3 hours ago, Daz said:
Need a ser 3 as apparently they are different
http://www.wiringspecialties.com/unrbwihatupr.html
Can confirm with these guys if they're different, but I'm pretty sure they're the same as it's the exact same engine with no extra sensors.
f**k 88e
My counterstrike skin has gone up in value $100USD since last week
Appears to be a bit of a price fixing - someone bought up all the case hardened stat trak karambits and relisted them for thousands of dollars, so genuine sellers have listed theirs for much less but still more than they were a week or so ago. Good times.
I can't believe people pay good money for that shit. And it's the gayest looking knife ever.
Even though I was watching the ESL matches last week in Sydney and made money live betting the rounds....
51 minutes ago, UNR33L said:
Shit knife m8
Skins don't get da kills
Skins get the money and if scarface has taught me anything, you'll soon find yourself the women
I never watched it all the way through though, so I assume happy endings for all
I used to think so too, but, since I'm making money off them, I say let them spend their Christmas money
I actually like the look of that one, but it's rarity that decides the value
Don't know how the whole skin economy hasn't been shut down yet by underage gambling laws, it's as pure as gambling gets
valve pls.
It was brought up in Europe I think.
5 minutes ago, dezz said:
Should you get the original windows CD when you buy a new laptop / computer with Windows installed?
not any more.
shit 3 laptops in our house not one has CD/DVD so would not be usefull.
should have a Certificate sticker on it and a copy of the installer on the drive.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
