not any more.
shit 3 laptops in our house not one has CD/DVD so would not be usefull.
should have a Certificate sticker on it and a copy of the installer on the drive.
Windows 10 is different, it doesn't have a sticker as all the licencing is done via digital fingerprints of hardware, so you don't even have to enter a licence key it just checks your machine vs a database and says yes/no.
not any more.
I just said CD as it was easiest but I meant hard copy.. For reinstall etc. I upgraded to Windows 10 via windows so I guess that means my copy was legit... Having it on the drive doesn't really help when you're laptop is a paperweight though...
You can download a tool to create the install media for you from Microsoft. It would not have all the drivers etc for the laptop on it though. You will need to download and install those from the manufacturer website.
https://www.microsoft.com/en-au/software-download/windows10ISO
so it is.
the 2 personal are 10 not noticed that.
not dealt with windows for a long time
I'll just boot up my laptop and download it...........
  • Like 1
17 hours ago, TiTAN said:
Pc case gear all the way.
they've also been done for the same thing hehe.. although microsoft are too nice, they used 4000 keys probably sold for about $200 each = 800k they only got fined 250k.
Edited by UNR33L
Boss is dead set on using win7 instead of 10 because of supposed issues with some software we use (I'm sure most of its been sorted with updates, but whatever). Dell is supposed to have win7 installed on it, but if it doesn't then I'm going to have to "acquire" a copy.
you can upgrade to 10 for free then just tell boss it shipped with windows 10
Careful with installing Win7 on modern hardware as MS have pushed hard to get the big manufacturers to stop providing Windows 7 compatible drivers for brand new hardware, if the box comes with Windows 10 you might be better off trying to enable compatibility mode for the app you are worried about.
this
i wouldn't be using windows 7 if i could help it
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
