not any more.
shit 3 laptops in our house not one has CD/DVD so would not be usefull.
should have a Certificate sticker on it and a copy of the installer on the drive.
Windows 10 is different, it doesn't have a sticker as all the licencing is done via digital fingerprints of hardware, so you don't even have to enter a licence key it just checks your machine vs a database and says yes/no.
not any more.
I just said CD as it was easiest but I meant hard copy.. For reinstall etc. I upgraded to Windows 10 via windows so I guess that means my copy was legit... Having it on the drive doesn't really help when you're laptop is a paperweight though...
You can download a tool to create the install media for you from Microsoft. It would not have all the drivers etc for the laptop on it though. You will need to download and install those from the manufacturer website.
https://www.microsoft.com/en-au/software-download/windows10ISO
so it is.
the 2 personal are 10 not noticed that.
not dealt with windows for a long time
I'll just boot up my laptop and download it...........
  • Like 1
17 hours ago, TiTAN said:
Pc case gear all the way.
they've also been done for the same thing hehe.. although microsoft are too nice, they used 4000 keys probably sold for about $200 each = 800k they only got fined 250k.
Edited by UNR33L
Boss is dead set on using win7 instead of 10 because of supposed issues with some software we use (I'm sure most of its been sorted with updates, but whatever). Dell is supposed to have win7 installed on it, but if it doesn't then I'm going to have to "acquire" a copy.
you can upgrade to 10 for free then just tell boss it shipped with windows 10
Careful with installing Win7 on modern hardware as MS have pushed hard to get the big manufacturers to stop providing Windows 7 compatible drivers for brand new hardware, if the box comes with Windows 10 you might be better off trying to enable compatibility mode for the app you are worried about.
this
i wouldn't be using windows 7 if i could help it
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
