2 hours ago, UNR33L said:
Isn't there new stamp duty advantages coming in July?
Missed out on these
Buy contract has to be signed after July
I still get 50% off though, and in the scheme of capital growth it wasn't worth waiting a few months / passing up the perfect property to save more stamp duty
I agree with my broker who rationalised that with no stamp duty for FHB will come more competition from other FHBs plus a possible increase in the prices of cheaper properties because of this, negating stamp duty savings. Or...more to the point: my time could have been best to buy while everyone else is waiting for 100% stamp duty savings, as my competition was mostly non-first home buyers and not many at that, due to the more first home buyer friendly price range I bought in.
After months of looking and some offers, I came to the conclusion that you do your research (growth, prices etc.), ultimately pay what the property is worth to you, and as long as you can service the loan the rest doesn't matter!
  • Like 2
13 minutes ago, Birds said:
Missed out on these
100% agree, when the right property comes up and if you can afford..just do it
  • Like 1
21 hours ago, Leroy Peterson said:
+1 for white le-roy
Which other real Asian guy???
My name pronunciation seems to change every 5mins...... the life of a real asian guy in a white organisation.
But is your name an easy couple of characters one or does it have like 7 characters making it all but impossible for someone that only speaks English to know how to pronounce it?
Or is this even after it has been romanised?
H U Y, it's easy as, 1 2 3
As simple as, do re mi!
1 hour ago, dezz said:
Who was it that posted that consumer law stuff about warranty not mattering, product working for a reasonable period of time etc...
What would be a reasonable period of time on an oven (residential)
Probably a few years; I don't know much about oven expectations. Where consumer law usually favours people is with short warranties like 12 months etc. Ultimately what matters is what you can argue is reasonable at VCAT should you take it that far - if your time is worth more to you then just try your luck at getting repair out of manufacturer or suck it up / buy a new one.
But yeah, back in the workshop days we had at least one case of someone who lunched their gearbox outside of warranty and when the new laws came in we had to replace it because they expected it to last longer.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
