Supercharger is really nice when someone in a Camry cuts you off or something and you need the instant 'f**k you' foot down smoke them up as you go around them.
Oh and going up the mountains you can basically sit in any gear you want
You don't get the rushing feel of torque like a turbo though, just because torque is basically flat through whole rev range, either will be a great mod.
Edited by UNR33L
Agree with Leigh - the choice between the two comes down to whether you want to go fast or feel fast
We clocked up more instant G force in my Skyline than his three hundred and seventy five kilowatts that walked away from me pretty easily
yes but how much of that was tyres ...  hook up lays a bigger part of instant g that power..
Was just foot down when rolling, both cars had grip.
Leigh's power delivery is just so linear that after the initial pull you barely feel it accelerating anymore...just see the speedo going up...probably also helps that you get to a given speed quickly so the feeling doesn't last as long either
Supercharging certainly seems more simple, less space, less heat issues, less custom work.
That pretty much is the winner for me. You can tweak chargers to suit your requirements and power curve with pulleys, belts and tuning?
If I'm gonna do it, should probably get it done before eofy.
Other thing to consider is warranty... Walkinshaw / harrop etc offer warranty, at a cost, haven't really looked into how it affects the manufacturer warranty if at all... But my mate recommended dynomotive or dpm, sounds like they offer more and better quality for less than walkinshaw etc...
I don't think EOFY really matters man... end of the day adding a supercharger to your work ute is not a deductable for a sparky.
Go the supercharger, you'll love it.
And yeah you can change boost by smaller pulley & the tune, e.g my car can be adjusted from low boost (3psi ish to 9psi ish stock standard) but if I want more than that I need to buy a smaller pulley to spin the supercharger harder. The problem here lies that then generally need the supporting mods like a turbo car, fuel pump, injectors etc.
That's great as long as you don't get audited.
Remember they compare you against the expected deduction for your salary & occupation class.
If you claim enough to stick out like a sore thumb it's going to be reeeeeeal hard to explain why you needed to add performance parts to your car that were not factory delivered.
2 minutes ago, Kinkstaah said:
Anyone know a decent auto elec that is mobile in Vic?
Not necessarily an "after hours cash only" style job, need a professional that can un-f**k a clusterf**k.
what happened? did you look at your car?
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
