Headaches wont be a problem as id be just paying someone else to take on the problem :30_no_mouth:
Lol famous last words.
Read through piggaz thread and see the effort he has gone to to get him happy with using the turbo (i know its piggaz, and he has endless cash, but its certainly a lot of work and ECU shit too).
Not sure the details of his build but didn't take Greg long to switch from a gtx to efr timeframe wise?
Doesn't take Greg long to do anything. Especially destruction, that's his specialty. You shouldn't base your thoughts on Gregs experiences. I'm sure he'll tell or has told you that personally.
  • Like 1
Experience must be good if he's willing to sell everything on the R34 apart from his turbo kit :3_grin:
Don't understand how mechanics can delay projects so long and the customer not crack the shits at them, shit wouldn't fly in most other industries.
I'd be picking the car up, cya later going to another shop
  • Like 2
Agreed, if i did that to any of clients they would have left.
Given that to build an engine assuming if you had all parts on hand and were working on it full time would only take a few days, but these cars just end up sitting in the corner for months
For me, it's partly my fault cos I changed a couple of things along the way.
Simple 2 weeks job turned into nearly 3 months and counting. They noticed an issue and spent some time chasing it to find nothing out of ordinary then I decided I want something else.
My credit card's gonna take a beating for sure!
It honestly depends on how happy you are and how much time/money you have.
Anything can ultimately fit and one person's easy is another person's impossibly difficult.
EFR's typically run about ~3000-3200.
Manifold and coating + shipping is $1750 ish. It took 8 weeks to arrive correctly.
External gate costs $600+ unless you find one second hand.
Fabrication work I needed would cost $2000 at Havoc.
You'll need to buy a pod filter, so that's another $100.
You will need to buy lines, GCG sell a kit for $400.
Heat beanie on turbo? $200-400 depending on brand.
Heat shielding for the "heat proof" lines kit GCG gave me? Another $300-350.
Vaccum lines, hose clamps, zip ties, random shit = $100
Tows to and from workshops/fabricator/AC place/To tuner = ????
20 hours of Labor = ?????
Tune = ????? (I DIY'ed mine and got it checked to be perfect in an hour, yay me)
It can get expensive, even if you do all your stuff yourself.
Other stuff:
Aircon line fouled, had to remove it at friends place with hoist. Do not attempt to do this because while we de-gassed the system (and had to abandon the garage, which was large... for 30 minutes, it also snap froze the welding glove being used to do it.
Then when it was de-pressurized, we removed the fitting to take the line off. An explosion happened, green "Stuff" went everywhere and we both held our breath and abandoned the garage again. It ended up costing $330 to get fixed later/re-fabbed and re-gassed.
We had to trim the bolt from an engine mount to fit the manifold too.
VS:
GTX.. buy turbo. Shit, buy one second hand! 3071's are cheaper than 3582's and EFR's.
Bolt on.
Reuse everything you already have. This assume your setup is good and working fine. Given you've kept it multiple years I'm going with yes.
Don't need to sell the 'extras' later. If you aren't DIY'ing the swap, you will save massively on labor.
Keep in mind my car is a 2.8, with a 3076 sized turbo running 17psi with a high stall converter. All of these things amplify torque and response a lot.
Most people go an 8374 with a 2.6 and say its possibly too small, let alone a smaller turbo with more motor.
I would sell my engine bay if someone gave me half of what it cost to do it. There is a vicious curve of diminishing returns at life above 300-320kw, and I can't honestly 'recommend' it unless you have the funds where it doesn't matter much to you, in which case I am more often saying "Buy a golf R with an APR tune" instead nowadays.
  • Like 2
mine was also near on 3 months, but mainly as I was in Germany for a period so we set expectations and dates when I first went in.
we had a time line with payment milestones and regular emails with status along the way
Had car back to them day after I returned (was keeping it at home during the build) and driving it the next weekend.
The thing is, there is no "another shop" to go to
All shops act this way, that would work on these motors.
  • Like 1
Other stuff:
VS:
Bolt on.
My aircon line is redone and re-routed because it blew last time on a racepace dyno. Cooler piping i was planning to get re-done atm, as it's massively long with a million bits that keeps popping on the track.
Yeah agreed what you are saying if i was going to go down a simple route of a simple swap then yeah GTX might be the way to go.
If i went down the path and going yolo ext gate, highmount then EFR.
At the moment its whether or not to put $$ and effort into a car i drive a few kms on the weekends. Honestly if i needed a daily for work i would prob just buy an E92 M3. But atm don't need one and feel like spending money on something #yolo
If only it were that simple.
I contemplated it many times, because 2nd engine job was almost at cost price so they weren't making any money, so day-to-day jobs would cut the queue... For about 4 months.
  • Like 1
I'd rather give them the ultimatum of a end date and if they don't finish on time you're not paying for anything and picking the car up? try the next shop, rinse and repeat.
If they agree on a timeframe they should meet it.
1 hour ago, UNR33L said:
Enough skyline talk.
88e
e85 e85 e85
Smashed avocado
800k etc.
Also birds your GTR should be external gated too <3
Hate external gates
No mod is more offensive to everyone around you and your own ears. Better for power sure, but the evo that drove past the other day and sounded like a cat being mauled reminded me why I don't like them
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
