Does it switch off once you're in the Bios? if so then looks screwed again.
If not.. check you can see your hard drive information in it and check that it's still set as your first boot device and make sure you've got no USB devices/Headphones plugged in (..yes I've seen headphones stop boot before)
Edited by UNR33L
Doesn't switch off in bios, boot order is usb then hdd, I assume that's so it would boot from a boot disk usb before hdd if you were trying to reinstall os etc? I didn't change any boot order so as far as I know that's the factory default boot order..
Only usb plugged in is the wireless mouse dongle which has always been plugged in...
Dezz I think you need to research which porn sites you visit dude...
I have had like 3 laptops in the last decade 1 x free macbook and 2 x < $500 PC's ... all 3 only died due to physical damage (1 x stepped on, 2 x kids)
Lol, the mrs has had corrupt video files and corrupt excel spreadsheets in the last 3 months.. I'm like wtf do you even do to cause this?
1 minute ago, TiTAN said:
Turn off, unplug power cord, Pull out battery. Leave for 5 minutes. Plug battery back in and try turning it on.
Do this, if error still occurs change boot device #1 to your hard disk
Was hoping to avoid pulling the mother f**ker apart for the 10th time after paying these mother f**kers to fix it.. But I guess I'll have to try that
1 hour ago, UNR33L said:
I'll PM you some info
Thx.
Also badluck Dezz.
My HP spectre i bought this year has been a dream so far.
Generally when i had any hardware issues they came onsite and fixed it on the spot
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
