Wont it just be the same cars that rock up at every meet?
Yep but pulsar hasnt been to a big meet in... Years. Plus gathering of VIP cars who havent seen in a while or freshly imported.
Fair enough we need to do a cruise soon
Pats car should be tuned and done in 2 weeks
  • Like 1
Such a hard life Liam.
Living away from home for 10months starts to take its toll. Lots of car friends to catch up with and a back-catalogue of work to do on cars.
If you want I can hook you up with some cheap Neons to make you feel better? (proper Neons, not that LED pleb stuff)
5 hours ago, Odium said:
Whats next for you?
So after being made redundant 3 weeks ago, i had another department at work ask if I would be interested in working for them.
basically some skills I have that is not replicated elsewhere withing the company that they need.
after discussing with with them, they are building a new role around me and my skill set rather than try and fit me in an existing role.
SO still a little bit of consulting, but more training of others in different offices and having oversite on processes and procedures for some of our partners and offices.
still locking in details but going to be a fun ride
  • Like 2
Basically they gave you a heap of money to change roles within the company.
It's a win for you, bit stupid on their part though.
i've been there for a while,
the IP I have in my head is worth much more to them than my salary...
basically they loose me, they loose near on 10 Mil of revenue stream as they cannot service it.
we have 2 people left who can maintain the product globally and one who can install..
that's the 2nd redundancy that I have come though in better position for.
this one however is all on me, its up to me to either make this role work which has great potential for future, or fail miserably.
and with more exposure, gone from 9 levels to CEO to 4
Reduced levels of management above you can be a good thing.
I have one level and a side step to the ceo, the extra exposure does come with the ability to be able to tell other people to just bugger off and that what you are doing is happening and they are just going to have to get over it and move on, which is great for getting shit done. Though if you have to deal with office politics that's less applicable unless you are at the yolo end of the do I look like I give a f**k scale.
If you are in a non-dedundantable (not a word) job position bringing in revenue to a firm of $10M. Then your salary should be like $5M
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
