32 minutes ago, Birds said:
I have those feelings with my R too and it's  not even on the road yet. It seemed more fun as a <20k car that I would be able to track occasionally. Now it seems irresponsible to have so much money tied up in a 20+ year old car when I could sell and get something cheaper or newer. Maybe I'm just finally growing up...
...nah
For me, it's a dumb move by myself by buying Das R.
Lately, I've been flirting with the idea of giving up both R's for newer Euro or some cheap Commo with forced induction.
R33 GTS-Ts going up in value...becoming less attractive as cheap track cars...
With my fresh paintjob and the above, a dilemma exists whether to go back to the track and have some fun at the risk of putting it into a tyre wall, or preserve it for future worth
Track it and have fun, yolo its still just a gtst. Its destiny is to be thrashed and enjoyed.
  • Like 1
13 minutes ago, Count Grantleyish said:
Time for Megane RS?
Good contender for a replacement! Problem is I love the uniqueness of Skylines these days. Call it attention whore, but Skylines turn heads these days even if it's because people remember them as hoon mobiles.
You're not wrong.
Only problem with Skylines these days, you can't leave it for 5 minutes without it getting destroyed one way or other these days.
  • Like 1
32 minutes ago, admS15 said:
Blasphemy.. get it together son
Haha
Someone (can't remember who) told me once you hit dirty 3-0 and it's all downhill from there... And they weren't wrong haha.
Car's been with me for 9 years now...fark where has that time gone. I have that thing where people have irrational attachment to cars. It's been with me through the best and worst times of my life :(
You're not wrong.
Truth
haha that's when I got into track days proper...
finally having proper disposable income was awesome
past 2 years for building house have killed me, but that should be over in a couple of weeks wondering if I can have the car ready for November Motokana
more likly early next year as want to do a few things to it first.
Car's been with me for 9 years now...fark where has that time gone. I have that thing where people have irrational attachment to cars. It's been with me through the best and worst times of my life [emoji20]
Unattach yourself from the gtst and attach to the GTR. Got to enjoy one of them freely.
Stupidly, I'd be less attached to the GTR. That GTS-T has seen some shit, man.
Which makes conceptual sense as the former would make a better track car. And a much more expensive write off :O
33 minutes ago, admS15 said:
Yep, this is how i justify my behaviour. Im almost pushing 40 but acting like im 25. Got to enjoy life and do the things you want to, within reason.
Fair enough.
Plus my interests are "wandering off" seeing I don't earn enough to have everything so for me, something's gotta give.
I'm at 6,9 and 19 years with my cars..
I made the mistake of persisting with the mustang when I should have moved on to other projects...
once I have my shed however it will only be a quick 10-19 years further b4 I give up
oh well.
  • Like 1
  • Like 1
Fair enough.
I hear you. The GTR is an appreciating asset though. You can hold onto it and occasionally drive when the bug bites and sell it for more later. That's a pretty unique situation to be in with a car. Maybe the das needs to be culled and replaced with a cheap runabout.
  • Like 1
oh well.
My Calibra is you with your Mustang, but worse because it's worth f**king nothing and it's got thousands of dollars in it like a $1500 Quaife LSD that I can't use in anything else lol
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
