Just now, Birds said:
Would you have posted if it didn't rise :P
Every stock I've posted has gone up significantly. I wouldn't recommend a stock if I hadn't done my research first.
Cant say I'd recommend 88e though ;) actually it looks like it's found support at ~1.7 might be good for a trade from here...
Same here...but ultimately there's always risk involved which is why no one jumps at it just cause someone says it. Wasn't until people started seeing me profit from 88E that I was able to get anyone onboard for the ride. FWIW when I first tipped it on here they were about 1.5 cents and went on to 8 cents within a few months. Whether people capitalised on that or not is another thing!
I agree 88E has found something of a floor until the next major news. You could just about guarantee a win from buying now and selling at the inevitable ramp up leading into well re-open...if you're patient enough to wait 5 months that is.
  • Like 1
28 minutes ago, Daz said:
I'll be recommending another stock soon (just building a position first :)
I'll follow if I have cash at the time - test your theory ;)
1 hour ago, Leroy Peterson said:
I was browsing stocks and went through 6 pages of VWL and couldn't find it :(
I've been watching MIN with interest lately...
MIN looks like a solid co, probably wait for a pull back :)
I'm trying to find the next company that will go from 1c to 1$ :)
I've been wanting to look into uranium, SLX has done well in the past when uranium price goes up.
Have MUS and BYE on my watch list but wasn't keen to jump on board... Then boom.
PLS has done some wonderful things. I forgot who tipped it to me but I've had it on watchlist and didn't invest. Now scaling back but has seen incremental consistent increases for last couple months.
Shock works and BC will rebuild their own shocks... Not sure about others.
Also, good luck getting discount rent for lack of services. My heaters been broken since August (urgent appliance needs to be fixed within 9 days) and all I get out of it is the ability to break the lease...
MIN looks like a solid co, probably wait for a pull back [emoji4]
I'm trying to find the next company that will go from 1c to 1$ [emoji4]
Please let me know when you find it. I've got substantial losses from an oil company that I need to recoup
  • Like 1
1 hour ago, Kinkstaah said:
Bilstein will rebuild them, but they're in Sydney and the turnaround time is ~3 weeks during which I have no car..
Therein lies my problem!
Quadrant in Berwick, they're Bilstein dealer IIRC.
Which reminds me, I should ask them if they have softer springs for my PSS9, worse case, Heasmans.
They were, and they are now closed/rebranded as "H&R". I went to them when they were still quadrant and they said that the place was for sale at the time.
Bilstein Australia actually said they have no local dealers. (via FB).
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
