8 hours ago, Birds said:
$75 gets you five dozen at Krispy Kreme
You know what to do
I have one KK a year just to remind myself how bad they are.
if your going to go a Donut it has to be a freshly cooked cinnamon one.
lost about 13 kg this year, plateaued out from diet alone, need to move to phase 2.
it's a bunch of cardio and weight room.
so basiclly everything I need in short term. When I need more I'll end up buying it and putting it in the shed.
was at the pub last night and it was Parma night! (you join the gym at the pub)  but the rowing club owns the pub so yeah.
can join the club as a Pub member for 5$ to get the discounts, or 75 for Gym membership and 150 for rowing membership.
http://www.nagambierowingclub.com.au/about/
5 minutes ago, TiTAN said:
How can they possibly survive on $75 a year memberships?
They're counting on people to give up and attend the parma nights instead. Everyone knows that gyms make the majority of their profits from markups on alcohol sales.
Inb4 pub on sells beer and parmas
According to some people gym equipment is straight forward to use, others are so anal about technique...
If you want the pin loaded machines to work the muscles that they are intended to work you need to be using it correctly. The more weight you are using the more important technique becomes as you are more likely to hurt yourself by doing it wrong.
Clearly we are missing out on some profits by not having liquor licences at our gyms. [emoji848]
Seems pretty standard. On my watch list. CPH did the same thing when it listed, then went below initial price over the course of a month, could be similar here being so pricey for pharma.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
