Mario cart in Tokyo was meh, thought I'd be as cool as Han driving through Shibuya crossing but I had more fun driving the Kei car to a few upgarages instead.
You f**king tripping m8
Driving around the city as a regular vehicle isn't very exciting. In fact, it's pretty shitty actually.
  • Like 1
  • Haha 1
Did you not play Tokyo Drift music the whole way? Missed opportunities
https://www.sau.com.au/forums/topic/458531-vic-wasteland-thread-150/?page=862
Seems like decent value unless there's something inherently wrong with the Cruze that I don't know about? I think I had one as a courtesy car when the ute was serviced... Didn't have the leather like this one but seemed like an alright daily in the short period I had it.
2014 model $9300 negotiable, 2011 model from a dealer asking $9900 both black.
A non car friend of mine is having a late 20's crisis and wants to buy a 2.0L BMW Z4. Told him to research it properly as there isnt any other rwd convertibles of that age at that pricepoint and probably for good reason.
2006 2L Z4 similar price to NA MX5. Pretty crazy,but at the same time, its almost worth the money just for the cash youd save annually on club reg.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
